WMAC Group build - Impressivo
11 years 5 months ago #1159 by simondean
Thanks David for your rapid response !
11 years 5 months ago #1160 by JonTappin
Sorry for letting you down Simon, I couldn't offer any advice based on my experience as mine is still in it's box :(
I'm doing better than Dave B though, he hasn't even collected his from me yet :)
11 years 5 months ago #1161 by kevinross
simondean wrote: After my last question met with no response I'll try again with a different one. Am I right to assume the best method of securing the servos is to glue them to the ply support ?? If so what's the best glue to use ?
This is not the best photo to show how i have secured the servos.
For each servo lug (4 off) I have made stacked up 3 squares of 3mm light ply to make a block about 15mm x 15mm x 9mm. Then cut a slot to locate the servo lug and glued the blocks to the ply servo plate.
You may also note that i have re worked the servo lead cut outs in order to keep the plugs inside the fuselage.
11 years 5 months ago #1162 by MikeSeale
kevinross wrote: For each servo lug (4 off) I have made stacked up 3 squares of 3mm light ply to make a block about 15mm x 15mm x 9mm. Then cut a slot to locate the servo lug and glued the blocks to the ply servo plate.
I'm possibly being a bit thick, but I can't understand what you've done here. Any chance of a clearer description for the hard of thinking?
11 years 5 months ago #1163 by MikeSeale
Re. servos...I always rought up the surface with a very coarse permagrit block to give the epoxy something to key onto. Only use a small blob of epoxy...it squeezed out and will need a lot of mopping up otherwise.
11 years 5 months ago #1164 by kevinross
Hope this is clearer
Time to create page: 0.339 seconds
