WMAC Group build - Impressivo
  • Phil-C
05 Mar 2014 18:38 #1495 by Phil-C
Kevin, please save the last prop for me.
Dave. I first of all used pan heads with a washer. Then I found the amount of shaft in the collett was a bit short, so I replaced the screws with some CSNK headed ones, and used lock tite to hold them in the CSNK holes in the rear bulkhead. I had in fact added a sheet of 1/32" ply outside the rear bulkhead at build time so the CSNK is in that thickness, so actual bulkhead not compromised.The heads are pretty well flush, so more grip on the shaft. Leaving out the 1/32" ply, and with the CSNK heads a bit proud, you will still gain on the shaft overlap
The surprise to me was no data sheet with ESC or motor.
05 Mar 2014 21:11 #1498 by JonTappin
Sign of the times Phil, it seems to be more common now that you are expected to download the instructions from a website :(
  • Phil-C
06 Mar 2014 11:20 #1501 by Phil-C
There is no data file for the motor apart from what is on screen. Power seems to be 660 W based on a customer test.
07 Mar 2014 06:36 #1503 by Phil Ford
660Watts? On three cells? That would equate to an input power of 59amps :blink: If you are using the motors that I think you are I would suggest that half that wattage figure would nearer.
07 Mar 2014 08:15 #1505 by MikeSeale
I measured 57A last weekend, Phil. I think you underestimate the motor we have. Now, I'm not suggesting that they will last forever at this power level, but all flights so far have resulted in cool motors on landing. Use of throttle in flight will obviously help...Jon!
07 Mar 2014 09:36 #1506 by kevinross
MikeSeale wrote: I measured 57A last weekend, Phil. I think you underestimate the motor we have. Now, I'm not suggesting that they will last forever at this power level, but all flights so far have resulted in cool motors on landing. Use of throttle in flight will obviously help...Jon!
Loadsanewpropsarrived - But they foul on my prop driver - Solution is to fit a spacing washer or in my case, turn a chamfer on the prop driver. However the current draw is down to 32 A which will result in longer flight times to suit the formation flying.
PS - If any body wants their prop driver chamfering, i have a small suitcase sized lathe <500watts which i can bring to cashmoor IF somebody has a portable generator with a 13amp socket.
07 Mar 2014 09:40 - 07 Mar 2014 09:43 #1507 by Phil Ford
I think I may have underestimated your motors :oops: - they looked a bit like they came out of a kid's toy car... :lol: But, hey! when you have burned out, I have a 3500kv going spare which is good for 60 amps on a 4.75 x 4.75, :P
Did I notice a hint that Jon was flying flat out?
Last edit: 07 Mar 2014 09:43 by Phil Ford.
  • Phil-C
07 Mar 2014 10:14 - 07 Mar 2014 10:22 #1509 by Phil-C
Kevin, as you enter the container to get out the charging table, you have to negotiate your way past a portable 240 V generator with a 13 amp plug on it. You may need petrol.
Please take outside before starting.
I could do with my prop driver chamfering.
Don't know about the two I have had on order for a while now from HK, as they seem to have been shipped somewhere else.
Phil
Last edit: 07 Mar 2014 10:22 by Phil-C.
  • Phil-C
07 Mar 2014 10:16 #1510 by Phil-C
These 480BL motors are 3200 kV
07 Mar 2014 13:24 #1514 by MikeSeale
PhilF51 wrote: when you have burned out, I have a 3500kv going spare which is good for 60 amps
Your motor looked nice but is about twice the price of the Turnigy as well as having a 3.2mm shaft (which I would have bent or broken by now). Also, it appeared to rev less than the Turnigy. This is probably due to its physical size...the Turnigy is bigger and will produce more torque, enabling it to continue delivering useful power when the smaller motor has given up.
Time to create page: 0.431 seconds
