WMAC Group build - Impressivo
  • istokes
08 Mar 2014 23:08 #1540 by istokes
Replied by istokes on topic WMAC Group build - Impressivo
Well that was Impessiv..........o !!!!!!!!!!!!!!!!!!!! .Sorry guys ..
But now on a posative note this leaves us with a new challenge,which one will be back in the air first?
I reakon they will all make it back but my guess is Jon"s next saturday?
Ian
09 Mar 2014 07:57 #1542 by DavidTappin
Very sad news, hard luck Simon, Dave and Jon.
Maybe my little health problem keeping me home yesterday did me a favour. I'll be fitting Robart hinges to my unflown Impressivo today. No doubt there will be more drag with the open hinge line but if flat out with a sealed hinge = broken I can live with that.
09 Mar 2014 08:14 #1543 by DavidTappin
As a matter if interest, did all three have their elevon horns on top like Jon's? I was a bit concerned about how weak the push rods seem and worried about them flexing in compression and allowing flutter. Mine are underneath like Mike's which has been reported as the fastest and, presumably, flutter free, but I'll be sleeving them with carbon tube to make sure they keep straight.
09 Mar 2014 09:01 #1544 by DaveBright
I'll admit, my hinging skills with film weren't great which was a major reason why mine went in. And yes, I believe all three of ours had top mounted servo linkages. We did comment yesterday on the fact we were asking a lot from a little piece of wire. Proper hinges and a more substantial servo linkages can't go a miss.
I thought I was safe having let everyone else bug fix last week! Combination of factors caused the high attrition rate...
  • chris.m
09 Mar 2014 09:22 #1546 by chris.m
Replied by chris.m on topic WMAC Group build - Impressivo
With regards to push rods why not use some 2mm helicopter ball link's with 2mm threaded rod sleeved with some carbon rod and lock nuts?
can buy one carbon rod split the cost and I would of thought there would be enough for several models?
same with the threaded rod I guess!!!
09 Mar 2014 09:41 #1547 by JonTappin
DavidTappin wrote: As a matter if interest, did all three have their elevon horns on top like Jon's? I was a bit concerned about how weak the push rods seem and worried about them flexing in compression and allowing flutter. Mine are underneath like Mike's which has been reported as the fastest and, presumably, flutter free, but I'll be sleeving them with carbon tube to make sure they keep straight.
The top horn point could well be valid, you are losing some mechanical advantage for sure. It is impossible to be sure if flutter caused the hinge to fail, or the other way round. When I rebuild mine, I am going to change to a bottom horn, with robart hinges and still seal the hinge line with film. Also the rods will be changed or stiffened with carbon tube. If it happens again after all that, it's going in the bin :angry:
  • Phil-C
09 Mar 2014 10:09 #1549 by Phil-C
I will be changing my linkages to 2 or 2.5 mm. I don't see why top or bottom makes any difference to strength (can somebody explain this?) Seems to me that if one linkage buckles while pushing in compression in a high speed manoeuvre, then, when the controls return to neutral, one of the surfaces goes too far the other way pulled by the bent rod, hence a rapid flip over and spin down. In Simon's case, spin not apparent due to low altitude. Clearly a design fault.
09 Mar 2014 10:16 - 09 Mar 2014 10:19 #1550 by JonTappin
Phil-C wrote: I don't see why top or bottom makes any difference to strength (can somebody explain this?)
Phil, it's about mechanical advantage, with the horn on top the distance of the drive position from the hinge point is the length of the horn, when on the underside, it is the horn length plus the depth of the aileron, probably an additional 10mm. Does that make sense?
Last edit: 09 Mar 2014 10:19 by JonTappin.
09 Mar 2014 10:23 - 09 Mar 2014 10:24 #1551 by JonTappin
Just checked my photos, Simon's linkages appear to be on the underside, mine and Dave's on top. I didn't hear any flutter from Simon's, it just rolled in, so that might have been a different cause??
Last edit: 09 Mar 2014 10:24 by JonTappin.
  • Phil-C
09 Mar 2014 10:39 - 09 Mar 2014 10:41 #1553 by Phil-C
Jon, understand now, thanks. Doesn't apply to my top mounted horns because the Kavan hinges are on the neutral axis of the wing.
Still going to thicken the links. Also try to remove the prop driver eccentricity
Last edit: 09 Mar 2014 10:41 by Phil-C.
Time to create page: 0.410 seconds
