Open TX
  • FlyBuster18
06 Dec 2018 21:04 #18401 by FlyBuster18
Replied by FlyBuster18 on topic Open TX
Hi to all, I have come to the point of having to purchase a new TX. My Spectrum has finally failed. So I am looking for advise on what to buy? I have been looking at Futaba T6K v2 *ch also the Hitec Aurora 9X. of course I am still under training so as both of these have training listed in their spec perhaps they will match up to the clubs sets for training. What do you think chaps.
07 Dec 2018 08:35 #18402 by Phil Ford
Ernie, I don't know why your title is Open TX. Open TX is open source software and the transmitters it can be installed on have to be programmed, a bit of a learning curve.
The two obvious choices here within this club are Spektrum or Futaba (leaving out Open TX and Frsky). We don't have any Hitec stuff either. Other members may throw their four cents worth in too due to brand bias but at the end of the day if buddy boxing is one of your primary needs then it has to be Spektrum. Not sure if our old Futabas are any good for slaves.
The following user(s) said Thank You: FlyBuster18
07 Dec 2018 08:59 #18403 by Chris73
Replied by Chris73 on topic Open TX
For once I actually agree with Phil :P
One of the new 6 channel Spektrum TX will do everything you need it to, I cant remember the model of the club trainer TX's, but one of those would fulfill your requirements
07 Dec 2018 20:49 #18406 by 4Pedalsfly
Replied by 4Pedalsfly on topic Open TX
Ernie - The latest Club Trainer transmitters are :
Spectrum - DX 6e
May I suggest you go that route and you will be fully compatible with the club gear.
07 Jan 2019 22:38 #18607 by Chris001
Replied by Chris001 on topic Open TX
Just curious, has anyone played with 'Instant Trim' in OpenTX?
You hold the sticks for straight and level flight, then flick a switch and the stick inputs are transferred to the trims.
07 Jan 2019 23:46 #18608 by DavidTappin
Replied by DavidTappin on topic Open TX
Very interesting.
I think I see what you mean about being curious Chris. I didn't realise that you need to have three hands to work Open TX, or doesn't it have trims on rudder?
08 Jan 2019 07:37 #18610 by Chris001
You surprise me David, surely the rudder trim is simply sorted on the ground, i.e. the only place it's really useful ;) , you taxi up and down the grass and trim the rudder so that the plane goes in a straight line. So with that one taken care of once you are in the air you can happily take your left hand off the throttle stick and flick the "instant trim' switch, and voilĂ , a perfectly trimmed plane.
08 Jan 2019 09:39 #18613 by John Bannister
Replied by John Bannister on topic Open TX
I've used instant successfully on slow moving planes that are easy to control and it does a really good job providing you are flying straight and level, the important thing to remember is that you are trimming all control surfaces at the same time, If the aircraft is a long way out of trim and say you need to pull back on the stick to keep it level, as soon as you use the trim switch the plane will climb until you center the stick. I tried using it on a foam MX which i was just getting used to and got it flying fairly well and trimmed, the weather was calm but the sun was low and bright in front of me, I waited till I was out of the sun flying level and flicked the switch with disastrous results the plane banked violently to the left and I was unable to control it. What I had done is, I had been worried that the plane was going to far away, unintentionally started to bank, flicked the trim switch which went to full aileron trim and I wasn't quick enough to save it.
08 Jan 2019 10:08 #18614 by MikeSeale
Replied by MikeSeale on topic Open TX
I guess the answer is that it can be useful but must be used wisely.
08 Jan 2019 18:42 #18626 by Chris001
It seems there are pitfalls to every shortcut!
Time to create page: 0.348 seconds
