Open TX
08 Jan 2018 09:03 #15304 by Phil Ford
I have done all that John. I did not use the config tool, I used the LUA script directly in the TX. Here you can calibrate and also configure all the advanced settings. My problem is the fact that when turning off the Gyro,(ie; for taking off) the rudder goes over to one side. Not a good idea.
08 Jan 2018 18:33 - 08 Jan 2018 18:36 #15308 by Phil Ford
The rudder issue resolved. Reflashed receiver, then went back into LUA script for configuration. Initiated self test again and voila! Had to go back into "outputs" to reverse elevator direction. On plugging in power with th eplane at wings level or slightly nose up the blue led on the RX flashes instantly and after gyro is initialised the ESC gets switched on. This is correct.
Just one more issue left. Stabilise and Auto Level appear to be working but is ignoring the switch position that says Off. I don't really want the Gyro in operation at take off.
Last edit: 08 Jan 2018 18:36 by Phil Ford.
08 Jan 2018 18:51 #15309 by Chris001
Replied by Chris001 on topic Open TX
PhilF51 wrote: Stabilise and Auto Level appear to be working but is ignoring the switch position that says Off.
Oh, I don't know Phil, maybe it know best ;)
01 Oct 2018 20:47 #17901 by Chris001
LiPo battery checker script
I've just tried this Lua script out:
www.craftandtheoryllc.com/lipo-battery-c...nis-x9d-x9d-and-x9e/
For it to work you need one of the flight pack voltage sensors.
I know the information is readily available on a telemetry screen, but I thought this graphical interface was better.
With the two scripts in there appropriate folders on the SD card I just selected a pre-existing model and set up the script as per the instructions.
02 Oct 2018 11:13 - 02 Oct 2018 15:18 #17916 by Phil Ford
Chris, here is my version. Total pack volts with cell volts. Programmed to voice me when Lipo pack voltage is at 22v and also at minimum (critical) I did try "Bars" but find this easier to read. If you have a cell that is always slightly low you can set it up to monitor that cell and warn you of whatever parameters you have set.
Can do so much with Open TX. ;)
Last edit: 02 Oct 2018 15:18 by Phil Ford.
27 Nov 2018 18:05 #18348 by Phil Ford
Another "just job" done. Upgraded the Taranis X9D to premium gimbals,.all metal with hall sensors. The gimbals have been gathering dust for a quite a time since Brian encouraged me to get some. They have a really nice smooth action but a bit of a pig to install. They are a very tight fit compared to the plastic ones that came out. Recalibrated the sticks and done. :)
28 Nov 2018 12:52 #18351 by Brian
Replied by Brian on topic Open TX
My new sticks had a slight problem, the throttle stick caused "Throttle Warning" at switch on. Now I wish I'd made a note of how I stopped it. Apart from that they have a nice "feel". My only criticism is that I'd like them to be firmer. Perhaps there's a way to fit stronger springs. Didn't think to look on the forum, perhaps there's a tweak in there.
28 Nov 2018 15:34 - 28 Nov 2018 15:35 #18352 by Phil Ford
The tensioner springs are paired together. one end on each has a screw that is not fully wound in. The flat spring strip gives you resistance and the other gives you the ratchet feeling (on the throttle stick gimbal)
I have set my throttle with very slight ratchet feel and light. The right stick has a bit more resistance. On the latter when I first took the gimbal out of the box, I needed a wrench to move the right-hand stick till I backed off the spring.:lol:
Last edit: 28 Nov 2018 15:35 by Phil Ford.
28 Nov 2018 20:54 #18353 by MikeSeale
Replied by MikeSeale on topic Open TX
Brian wrote: the throttle stick caused "Throttle Warning" at switch on. Now I wish I'd made a note of how I stopped it.
When you 'calibrate' the sticks you can pull the throttle stick below its normal resting low throttle position. The solution is to make sure you gently pull the throttle stick to its low throttle position whilst calibrating.
Brian wrote: My only criticism is that I'd like them to be firmer. Perhaps there's a way to fit stronger springs. Didn't think to look on the forum, perhaps there's a tweak in there.
As Phil has already pointed out, you can adjust the tension. But I found that they were still a little soft for my liking, so I replaced the M9 springs with the springs from the old gimbals. These springs are a couple of mm shorter and made a lot of difference to the feel of the sticks. It was a fiddly job, but well worth it, especially since I am using long sticks which have the effect of softening the feel anyway.
01 Dec 2018 08:04 #18365 by Brian
Thanks Mike, didn't realise the original springs were shorter, I assumed it was the longer sticks of the X9E that were causing the difference in "feel".
Time to create page: 0.709 seconds
