JR Powersafe Receiver
9 years 11 months ago #6751 by Chris73
Replied by Chris73 on topic JR Powersafe Receiver
It's under a year old, don't think I will have the receipt anymore though
Anyway, first job is to change the connectors and then methodically work through it all so I know which bit has failed
9 years 11 months ago #6753 by JonTappin
Replied by JonTappin on topic JR Powersafe Receiver
Chris73 wrote: It's under a year old, don't think I will have the receipt anymore though
If you do find that its faulty, let me know, I can probably help you with that.
9 years 11 months ago #6755 by Chris73
Ok, think I may have solved it, whilst testing the voltage of each pack I found that if I wiggled the live wire just in the right place on one the packs I could get the voltage to drop from 8.2v to 4.3v. So that pack is now being thrown away and I have a new pack. Still going to change the connectors so I can get rid of the adaptor as this is just another failure point, fingers crossed this will solve the problem.
Will have a couple of flights at the weekend and then check the packs just to make sure
9 years 11 months ago #6756 by JonTappin
I'd be surprised if that isn't your problem Chris, as soon as the voltage drops the rx will take power from the other pack, under vibration it is probably happening constantly.
Do as you suggest though and check after a couple of flights.
9 years 11 months ago - 9 years 11 months ago #6787 by kevinross
Replied by kevinross on topic JR Powersafe Receiver
From a safety point of view, most of us commence our flying day with a range and failsafe check but how do those of you using power safe receivers know both batteries are feeding your receiver. I know Chris always checks the recharge Qty of each battery which is how he has detected the problem but isn't it too late AFTER your flying session.
Would it not be better if as part of your preflight checks to disconnect each battery in turn BEFORE flying.
I don't have any powersafe Rx but feed all my dual power feed RD921 Rx with two batteries via dual switches & diodes Or a dual powerbox
switch so i can check each battery will individually power the R/C
Last edit: 9 years 11 months ago by kevinross.
9 years 11 months ago #6791 by
Replied by on topic JR Powersafe Receiver
slight fork of topic...
another thing i like about the Jeti gear.
the regulators that Jay and paul are using have telemetry on them, they tell you voltages of both packs and the rx tells you the voltage it is seeing. You can then set alarms for minimum voltages.
