Covering
8 years 5 months ago #12736 by Chris73
Replied by Chris73 on topic Covering
I used a pen that is designed for sealing the edges of graphics, I only sealed the front edge of the point as that will be in the airflow
8 years 5 months ago #12737 by Phil Ford
Replied by Phil Ford on topic Covering
Chris73 wrote: Needless to say, but I did'nt go with Mike's suggestion
Good job too! Would've started a forest fire.:silly:
8 years 5 months ago #12747 by JonTappin
Replied by JonTappin on topic Covering
AlanF wrote: Nicely done Chris.
Did you seal down the edges of the film after covering, if so what did you use? I've used a Solar Film product called Clearcoat on my glow models in the past which has worked ok but haven't used anything on the Gas models.
Edit:
That's not true I've used it on my little Extra - it works ok !
I use one of these, lasts for ages and easy to apply
www.signmakingandsupplies.co.uk/seal-it-pen-17298-p.asp
The following user(s) said Thank You: AlanF, Brian
Time to create page: 0.404 seconds
