8 years 10 months ago #10958 by Phil Ford
If you can get up to Cashmoor tomorrow I can take the Acro home and see what the problem is Lee. Then I give you a rundown on the situation so you will know if there is ever another model with the similar issue.
8 years 10 months ago #10961 by Brian
Lee, if you reversed the servo, you must re-bind the receiver's fail safe, otherwise you'll have the engine going to full throttle if you have a radio problem.
8 years 10 months ago #10980 by
Brian, Fail safe redone done that straight away, but thanks ;)
Phil that would be extremely useful thanks :woohoo:
8 years 10 months ago - 8 years 10 months ago #10981 by Phil Ford
I'll probably be up on Saturday Lee, so I can take the "thing" home or at least give me the engine. I can set up the latter on my test bed and sort it.
Trying to do indoor jobs as much as possible due to the cold weather....... ;)
8 years 10 months ago #10984 by
if your about at home this afternoon i can pop the "thing" in lol
agree its bloody to cold out !
8 years 10 months ago #10985 by Phil Ford
You fancy a trip to Christchurch? :unsure: I'll be here. Have sent a message.
Time to create page: 0.770 seconds
