8 years 10 months ago #11045 by Brian
Well! I joined WMAC with the general idea that I'd be among fellow model flyers. I had no idea at all that I'd be able to learn to spell properly, fix a reluctant engine, get a masterclass in rebuilding, and all sorts of interesting things that continue to bring lots of information as well as a great deal of amusement. I'd like to thank you all for the banter that's going back and forth.
It helps a lot when the temperature in my shed is hovering on zero and I have a couple of models that need a lot more TLC before they can be flown, makes me feel that it'll be alright in the end, and what seems like a real pain to fix, is after all, just another niggle to be laughed at. It never occurred to me that it might be possible to take off the cowl of an AcroWot without removing the prop and spinner, and as for Phil being all alone on the field and playing with himself...............mind boggling.
I'm sure that's what he wrote.
8 years 10 months ago #11049 by 4Pedalsfly
Replied by 4Pedalsfly on topic Help required OS 70 - 4 Stoke (Acro WOT)
Brian - You quoted Phil correctly - quite an achievement on such a cold day !!!!
8 years 10 months ago #11050 by Phil Ford
4Pedalsfly wrote: Brian - You quoted Phil correctly - quite an achievement on such a cold day !!!!
It WAS! :lol:
8 years 10 months ago #11051 by
To remove cowl without first taking off prop. Use a rubber prop, just like the KK ones of yesteryear. When you ran the engine, the pitch went to zero!
Stuart
8 years 10 months ago #11053 by
JRI wrote: ....Whereas a WOT is simply the equivalent of a Wartburg or Trabant in a car park (cheap and practical - but embarrassing )!
You forced me to google both Wartburg or Trabant, I'd never heard of them. Anyway, I love the description:
Dubbed a "spark plug with a roof", the Trabant was produced for nearly 30 years with almost no significant changes to its design.
What plane could be appropriate be dubbed a "glow plug with a wing"? the rest of the sentence might be appropriate too ;)
Regarding my heritage Mr. JRI it's beyond reproach, and how very dare you to suggest otherwise. ;)
Regards, Gromit
8 years 10 months ago #11054 by DavidTappin
Replied by DavidTappin on topic Help required OS 70 - 4 Stoke (Acro WOT)
Stuart remembered
One of the earliest application of the recycling process, in this case by donation from disused red polythene washing up bowls.
