Extreme Flight 104" Extra
12 Feb 2016 19:56 #7981 by Chris73
Replied by Chris73 on topic Extreme Flight 104" Extra
Ailerons now hinged, servo's fitted to the stabs and the landing gear mounted.
Tomorrow's jobs
1) Install the servos in the wings and make up the leads
2) Fit engine and exhausts
3) Start making the extension leads for the elevators and rudder
I will take some more pics tomorrow when I start making the leads
12 Feb 2016 20:20 #7982 by Chris001
Replied by Chris001 on topic Extreme Flight 104" Extra
Sounds like you are making good progress Chris, will the MTW tuned pipes help with your lack of power at take off? I'm assuming you've gone with your original plan and pulled the servos and engine out of the Yak?
12 Feb 2016 20:49 #7983 by Chris73
Don't think the pipes will help with that, but I have got a new reed block, reeds and carb diaphragm , plus all new reed block and carb gaskets. Hopefully that will sort it, oh and a new set of plugs
13 Feb 2016 09:45 #7985 by flyingpete
Replied by flyingpete on topic Extreme Flight 104" Extra
Nice work Chris!
13 Feb 2016 10:50 #7987 by Chris73
Extension leads made and braided for the tail, I used powerbox cable and crimps, using their crimping tool made this fairly quick and easy. Apart from setting up the throws that's the tail finished. Going to start making the leads for the wings now, while the wife has volunteered to go up B & Q to get some silicon so i can fit the landing gear cuffs :)
13 Feb 2016 13:27 - 13 Feb 2016 13:27 #7988 by Chris73
That took longer than I thought but the extension leads for the ailerons are now made and braided, also fitted the servos and control rods. Just got to set up the throws and the wings are finished :)
Last edit: 13 Feb 2016 13:27 by Chris73.
13 Feb 2016 15:08 - 13 Feb 2016 15:12 #7990 by flyingpete
Bloody hell chris!! You will need to have a lay down before you burn yourself out :P
Great job,like the new powerbox lead's ! Must give them a go
Last edit: 13 Feb 2016 15:12 by flyingpete.
13 Feb 2016 16:54 #7993 by Chris73
Didn't get much done this afternoon, took the 3W out of the Yak and then replaced the reed block with an Ali one, plus replaced all gaskets, then stripped and cleaned the carb, replaced the diaphragm and all gaskets and put in a new set of plugs for good measure.
Hopefully get the engine mounted and plumbed in tonight.
13 Feb 2016 17:58 #7994 by S.rotor
Replied by S.rotor on topic Extreme Flight 104" Extra
Nice motor and air frame pipes? ???????
13 Feb 2016 18:52 #7996 by Chris73
Engines in :woohoo:
Going to try it without the velocity stack to start with to save cutting the cowl, not really sure what it does anyway??
Time to create page: 0.438 seconds
