Mini LecRoo
21 Nov 2018 17:22 #18317 by Phil Ford
Replied by Phil Ford on topic Mini LecRoo
Spurred on to do something constructive by the inclement weather I presume? :lol:
  • 4Pedalsfly
21 Nov 2018 17:31 #18318 by 4Pedalsfly
Replied by 4Pedalsfly on topic Mini LecRoo
Phil Ford wrote: Spurred on to do something constructive by the inclement weather I presume? :lol:
Spot on Phil - watch this space for more project updates.
22 Nov 2018 14:30 #18319 by Brian
Replied by Brian on topic Mini LecRoo
Doesn't time just fly by Colin, I don't think your build time is excessive. I started a project in the twentieth century, didn't get to finish and fly it until the twenty first. My current model on the board was started a few years ago, but what the heck? As long as you're doing SOMETHING, that's what matters. Let me know if you'd like me to launch your LecRoo when you get it to Cashmoor. Keep the pics coming!
23 Nov 2018 17:34 #18320 by simondean
Replied by simondean on topic Mini LecRoo
Looks like you're making a nice job of the build.look forward to see it in the flesh once completed.
  • 4Pedalsfly
23 Nov 2018 20:47 - 09 May 2021 15:42 #18323 by 4Pedalsfly
Brian wrote: Let me know if you'd like me to launch your LecRoo when you get it to Cashmoor. Keep the pics coming!
Brian - Based on your superb launch of my Zagi using skills honed in your free flight days - Yes Please.
My longest build was 15 years, model started in Birmingham & finished in Ferndown, sadly crashed on her maiden flight
but was repaired and flew well.
Last edit: 09 May 2021 15:42 by Phil Ford.
  • 4Pedalsfly
09 Feb 2019 20:41 #18862 by 4Pedalsfly
Project moves forward at it's steady slow pace.
Covering now underway, I'm using TopFlite " MonoKote" film which was purchased in the
States over 7 years ago but the adhesive is still good.
I cut paper templates for each item which are placed over the film to minimise waste.
Three pics below - One more to follow.
  • 4Pedalsfly
09 Feb 2019 20:45 #18863 by 4Pedalsfly
Last picture - Fuselage covered, now onto the wing -watch this space.
09 Feb 2019 22:41 #18864 by kevinross
Replied by kevinross on topic Mini LecRoo
good to keep busy during the current weather Colin. Id love to be sticking balsa but having to do emergency lathe maintenance
10 Feb 2019 10:26 - 10 Feb 2019 10:28 #18865 by Brian
Colin, as instructed in the Feb 9 post,I watched the space. Nothing happened so I gave up after two hours. Nipped down to the shed as the rain had stopped, glued and pinned the pieces of balsa and ply that I'd prepared on Saturday. I found the envelope that the Wot Knot plan came in. The postmark was 2006. The build started that year, and at the rate its going now, I'll not be finished this year, not unless I can find a fresh packet of enthusiasm, the old one ran out sometime last year.
Last edit: 10 Feb 2019 10:28 by Brian.
  • 4Pedalsfly
29 May 2019 23:00 #19685 by 4Pedalsfly
At long last the model is finally ready for her maiden flight, pics attached.
I've fitted a tow hook so I'm planning a bungee launch off the ramp for the maiden flight,
then hand launches for subsequent flights.
Model weighs 2 1/4 Ibs, current draw of 50A giving 550W = 248 W per Ib with a wing loading
of 11 ozs per sq ft, so ample power with a light wing loading.
Motor is EFlite inrunner 3,200 kv turning a 6x4 prop, battery 3S 2,200 LiPo
Just waiting for a suitable weather day and off she will go.
Time to create page: 0.972 seconds
