- Thank you received: 0
I need to wait until Halfords in open and then find a blue and an orange that are similar to the covering. I'll either extend the colours straight forward or might curve then to a point so the front of the cowl is completely white.kevinross wrote: Looks super Mike and no mistaking which way up as you exit a spin. Whats your plan to paint the cowl.
I have an unopened box of balsa from Balsa Cabin that has enough wood for at least a couple of models. I'll probably do an own-design slope soarer of about 2m wingspan.Phil Ford wrote: A good job done. A very easily orientated scheme Mike. Blue/Orange is the modern look.
What's the plan for the coming week now?
JonTappin wrote: Attached is the only pic I could find of my now dead Sukhoi, not crashed due to orientation issues
No and no. IMHO, the last thing you would want to do is seal the balsa before applying any heatshrink film. You want any air to be able to expand into the grain of the balsa as it is heated. To be honest, covering a foam wing using film is not easy because the foam is airtight. So for a built up wing you might seal all the edges before shrinking the film, but with a foam wing (or any soling surface) I lightly tack corners and edges every 10cm or so and then work from the centre outwards. This avoids trapping too many air bubbles.Brian wrote: I like your choice of colour scheme Mike, its almost like looking at two different models. Do you seal the balsa before covering, and do you use a primer on the overlaps in the film?
Phil Ford wrote: Mike, if the dark blue is Oracover 52...
Why would you assume Oracover. You know I'm [strike]a tight git[/strike] careful with my money.
MikeSeale wrote: .
As for sealing the edges of overlaps, I know Jon does seal his overlaps after covering (perhaps he can link to the product he uses?)
