Stearman build
4 years 10 months ago #23825 by kevinross
The joystick is K & S alloy tube, some rubber bushes mounted with a coil spring. (it wont move with the controls )
The seat mounting is loosely based on the full size but more importantly will easily remove with its backplate for servo access.
4 years 10 months ago - 4 years 10 months ago #23826 by kevinross
Most super Stearmans have a turtle deck. I made the formers then John Jacobs to cut me a foam core which I wrapped with light balsa. I'll need to apply the covering before final blending with the fuselage.
Last edit: 4 years 10 months ago by kevinross.
4 years 9 months ago #23837 by kevinross
The last few days has required more thinking than doing and now my brain hurts, so made a start on the .8mm ply decking and Initial shaping of rear windscreen .
4 years 9 months ago #23927 by kevinross
Been busy prepping ITRO 200 parts which i have to convert into 4 wings. Due to the kits age, some parts have warpage so in order to pull everything square when the glue sets i've used this alloy extrusion left over from a previous project to make a building jig.
4 years 9 months ago #23936 by kevinross
The standard build is for basic Stearman which only has lower wing ailerons. I'm converting to a Super Stearman with 4 ailerons so modifying some upper wing ribs.
with all that complete ive grouped all the ribs for final sanding / shaping to match the spar cutouts and notches - Now all 76 main ribs assembled dry on my jig to verify they all align. Then there are 30 lower aileron ribs and will have to make another 20 for the upper wing. (so the part count soon adds up)
The following user(s) said Thank You: 4Pedalsfly, DavidTappin, Phil Ford, Brian
4 years 9 months ago #23937 by Brian
There's an amusing chapter in Jack Currie's book Wings over Georgia, where Jack goes low flying in a Stearman, he reckoned he was looking for alligators, got caught by the CFI and nearly got booted off the course. Makes very good reading.
