Hinge Line Options
10 years 5 months ago #4381 by AlanF
Replied by AlanF on topic Hinge Line Options
Nice one Phil, are you going to glue both surfaces at once or one at a time, epoxy, resin W, or gorilla glue - we're on the edge of our seats we need to know the results :)
Good luck for next week!
The topic has been locked.
10 years 5 months ago #4383 by MikeSeale
Replied by MikeSeale on topic Hinge Line Options
chris.m wrote: Resin W waterproof pva works well to
Sometimes you do things the way you do because you've always done it that way. PVA certainly would be a lot easier to work with than epoxy...I'll give it a try on my next build/
10 years 5 months ago - 10 years 5 months ago #4385 by Phil Ford
AlanF wrote: Nice one Phil, are you going to glue both surfaces at once or one at a time, epoxy, resin W, or gorilla glue - we're on the edge of our seats we need to know the results :)
After a few dry checks I will go for both surfaces using 30 min epoxy. Once the edges are virtually touching, then flex the control surface through 45/50 degrees each way (or the angle of the leading and trailing edges). That should align all the hinges so there is no tension between them. I used this method on the Mustang which had recessed hinges with excellent results. On the latter I used the wife's Dove stuff to lubricate/protect the hinge pin and then cleaned off with a Qtip. :lol: Smells nice too!
I have also done it control surface first, setting hinges to sit 90 degrees to surface, but are they 90 degrees? Using a set square and eyesight? But then they could be 88 or 92 due to the short distance to measure against.
PVA? Now that's a thought, because it only sticks wood but has no hold on plastics, but the only thing I believe it has not got is some degree of flexibility which epoxy has.
This thread has certainly brought up some interesting views and methodology :lol: Is that last word legal?
Last edit: 10 years 5 months ago by Phil Ford.
10 years 5 months ago #4386 by Chris73
Replied by Chris73 on topic Hinge Line Options
[/quote]
[/quote]
All the epoxy i have used goes off like rock, so i doubt there is much flexibility in epoxy. The hinges on my 50cc Yak54 were glued in using PVA and none have come loose over the last 18 months (Tempting fate i know), you just have to make sure you get plenty in the hole, and like Chris said its real easy to clean up any excess
10 years 5 months ago #4387 by Phil Ford
REWIND - In fact I have glued the hinges in the control surface first. Why? Well on dry fitting the pin centres move around when flexing the surface against it's companion, gradually opening up the gap. Not good! Whereas if the hinge centre pin is flush with the edge and glued it cannot move. Will find out if this method is best policy in a few hours when the epoxy has set and go to fit the rudder to the fin... ;)
10 years 4 months ago - 10 years 4 months ago #4605 by Phil Ford
Classic CAP 232 40cc - 60cc
As you can now guess I am able to sit a table to fiddle with models. Better half fetches and carries. :kiss:
Glueing Hinges! Definitely one surface at a time. Control surface first. To refrain from having to cut slots for the pin hinge heads I counter bored the hole slightly and ironed the film where necessary. Bevels now are virtually touching. :) Minimal gap, less chance of flutter.
Another question - Using HD control horns (Miracles from Probuild) , should I epoxy the horn screw in the surface as well or just thread lock the securing nut? Also is 1/2inch the standard distance between the hinge line and the horn screw?
Last edit: 10 years 4 months ago by Phil Ford.
Time to create page: 0.245 seconds
