Hinge Line Options
10 years 4 months ago #4607 by MikeSeale
Replied by MikeSeale on topic Hinge Line Options
PhilF51 wrote: Also is 1/2inch the standard distance between the hinge line and the horn screw?
If the hole in the control horn is 1/2 inch in front of the horn screw, yes. This will make the hole line up with the hinge line for the best linkage geometry.
The topic has been locked.
10 years 4 months ago #4610 by
Replied by on topic Hinge Line Options
Bit late joining topic, but, I use epoxy, one surface at a time. Also, a drop of oil or vaseline on the pivot point. Using second surface to ensure alignment. Holes were c'bored if required.
Stuart
10 years 4 months ago #4612 by Phil Ford
Thanks for confirming Mike. The ball link hole does line up with hinge line. I asked for confirmation as the holes were already drilled at factory and I did not want disimilar geometry. This model has no manual and quite a few bits missing but I found that the Hangar 9 Cap232 manual (model discontinued in 2010) is very similar so following some of the build sequence.
So, do I glue control screw or not into control surface?
10 years 4 months ago #4617 by JonTappin
Replied by JonTappin on topic Hinge Line Options
Hi Phil
Hope the recovery is proceeding well.
I asume you are talking about the horn type with a plastic triangular base with a plate on the other side? If you are, for added security, I normally remove some of the film below the base plate, stick a pin or knife blade point into the surface of the exposed wood to create small holes, then partly assemble the horn with the screws, then before fully tightening down, soak it in thin cyano then quickly tighten the screws. This reinforces the wood, bonds the base to the surface and locks the srews all in one go.
10 years 4 months ago #4621 by Phil Ford
Recovery proceeding slowly but surely Jon. Thanks. Can sit at bench now for a while to fiddle with stuff..... :lol:
I have stepped up the game now regarding new aquisitions. :lol: I am talking M4 HD control horns and rudder dual horns. In the Hangar 9 CAP232 50CC manual, it says epoxy screw and then thread lock the securing nut. I am just enquiring wether it is really necessary to glue screw. I would've thought some thin CA in the hole to harden the surrounding balsa would suffice.
10 years 4 months ago #4622 by JonTappin
Those are good horns, I would still do similar to what I posted earlier, assemble on the control surface, wick in thin cyano then immediately tighten, it won't be going anywhere!
