A little more feedback from testing yesterday, where I managed 5.01 flights.
The first flight was the 0.01! I had trimmed it after the initial flight during the week and did not add back in the 1mm up elevator. That was a mistake, because the model hit the ground and sheared the blades off the prop. It carried on running for a while but the vibration then sheared one of the motor cables where the connector is soldered. These cables are very stiff and long and closer inspection shows that it had work-hardened prior to shearing, so would have gone one day anyway. Lessons learned:
- always launch with +1mm
- shorten the motor wires and/or be careful not to bend them too much where the connector is soldered
The forecast was not too good so I called it a day until 1pm when it looked like it might stay flyable, so I went home and re-soldered the connector and got back to Cashmoor by 2pm. Five more uneventful flights with different props. There is not a lot of difference between the 5.5x4.5, 5x5 and 4.75x4.75. The 5.25x4.75 was on the midweek maiden flight and was the one that broke today. This also had very similar performance. I also tried the 4.7x4.2 which was definitely a little slower and would probable be the best choice for formation flying.
As for the flight performance, all I can say is wow! The speed compared to the Twinjet (and Phil's x-wing) is like chalk and cheese. At full power it appears to climb vertically without any loss of speed and gets small very quickly. The conditions were very windy by the end of the day and the Impressivo cut through it very cleanly. One or two landings were less than perfect, due to the turbulence, of course! One prop broke on landing, so make sure you have a few spares to keep you going.
