FrSKY Taranis X9E
  • Stuartmck
19 Mar 2018 16:40 - 19 Mar 2018 16:41 #16083 by Stuartmck
Replied by Stuartmck on topic FrSKY Taranis X9E
Dead right!
Stuart
Last edit: 19 Mar 2018 16:41 by Stuartmck. Reason: Too many capitals
19 Mar 2018 17:29 #16084 by Brian
Replied by Brian on topic FrSKY Taranis X9E
I don't think that either of you will get packing rings now, better stick with your old fashioned R/C gear.
19 Mar 2018 21:38 #16087 by Chris001
Replied by Chris001 on topic FrSKY Taranis X9E
kevinross wrote: If somebody provides me with a diementioned drawing - i'll see if i have suitable alloy material to machine some for you. - with free click and collect @ Cashmoor
Thanks Kevin, I'll hope to have a drawing for you later in the week, and you can see if it's doable.
All the best, Chris
20 Mar 2018 13:25 #16092 by Brian
Improved "suspension" arms. They don't fold, but they do fit inside the carry case.
20 Mar 2018 13:32 - 20 Mar 2018 13:43 #16093 by Chris001
Hi Brian,
Where did you get the arms I was looking to modify a transmitter mitt for the X9E and a set of these would be just the ticket.
Would also be interested to know how you attached them to the X9E, although I don't have an issue with the current ones, but did have to change the strap, the clips were just too small with cold fingers on top of a hill with snow coming at me ;)
If JRI reads this he'll probably link to this video:
Last edit: 20 Mar 2018 13:43 by Chris001.
20 Mar 2018 13:43 #16094 by Brian
Chris they are Horus neck strap supports from T9HobbySport. I retained the main alloy channel, and two clamp plates from the original build. The alloy channel has to be drilled 6mm dia. to accept the fatter arms. Much easier to "hook on". I didn't know whether to publish this, I didn't want to upset "Trig", or his broom.
20 Mar 2018 13:47 #16095 by Chris001
I can't seem to post the video, but yep it was Triggers Broom.
Thanks for the info Brian.
21 Mar 2018 08:52 #16118 by Brian
Oops! The new arms fitted into the position of the original support arms doesn't work all that well. The arms are well over to each side of the X9E case and get in the way of the backs of my hands. I expect its because I'm a stick pincher, only because the other method of control is "thumb-thing" I never managed all that well.
22 Mar 2018 11:28 #16130 by Brian
The Horus arms now fit the X9E case. I hoped to be able to leave the original alloy arm support in place, however, it isn't possible to assemble the back cover to the transmitter with the support arms fitted. I'll replace the screws supplied with socket head screws and T nuts fitted into the back cover. This will enable the arms to be fitted after the transmitter case has been closed up.
24 Mar 2018 13:28 #16166 by JRI
Replied by JRI on topic FrSKY Taranis X9E
Is this what you are trying to achieve?
Time to create page: 0.761 seconds
