8 years 7 months ago - 8 years 7 months ago #12030 by Phil Ford
Replied by Phil Ford on topic New Model, first adventure into petrol
Re-your PM. You can use one or many as you like receiver batteries. On bigger planes it is favoured for two Lipos, 7.4v (through a regulator) or Life (6.6v). In other words wire up as any other of your aircraft. ;) For ignition you want a smaller battery (ignition doesn't consume many milliamps) maybe a 4.8v nimh pack which i am sure you must have lying around. This battery then powers the ignition via the Kill Switch. The Kill Switch is optically isolated so there is no connection between the two circuits. The ignition circuit's on/off signal is derived from your preferred channel on your TX. Being an aerobatic plane without retractable gear, use the gear switch (ch5) or assign one of your choice that is not used.
Hope that helps.
Not sure where Frank put the ignition module but needs to fairly close to the engine and locate your receiver well away from it. (Stray HF interference).
Last edit: 8 years 7 months ago by Phil Ford.
8 years 7 months ago - 8 years 7 months ago #12032 by Phil Ford
Sorry Simon did not read all your message. Busy with soldering iron and microchips.
I have scribbled a schematic that may help you below. Personally I use two 2100 Life RX packs from HobbyKing UK ,Y-leaded together. That gives me 4200maH capacity. Switched off by a heavy duty switch with LED, that reminds me to turn off. ;) At the end of the day though unplug them.
Ignition LED! Place it so it is visible on the outside of the fuselage. I usually bore a 5mm hole then push gently the LED through till the little lips stop it. Hold it with a blob of UHU or silicon sealer. If you have the LED bezel that should come with th e kill-switch, then drill out to around 6.5mm for the bezel and then push LED into it. Blob it with UHU.
8 years 7 months ago #12033 by kevinross
Replied by kevinross on topic New Model, first adventure into petrol
PhilF51 wrote: Sorry Simon did not read all your message. Busy with soldering iron and microchips.
Phil - your practice of connecting two batteries in parallel is not ideal because it does not provide power failsafe. It is better to feed each battery via its own switch and an independent isolation diode. Either by constructing your own with a heavy duty switch and a Schottky diode such as this
www.maplin.co.uk/p/mbr1535ct-15a-schottk...rier-rectifier-n13cc
or splash out and buy a Powerbox failsafe switch.
www.nexusmodels.co.uk/powerbox-systems-p...sor-sparkswitch.html
Personally, i think that all models ITRO 7kgs and above should have a dual failsafe power supply.
8 years 7 months ago - 8 years 7 months ago #12035 by Phil Ford
Hi Kevin. I have considered a Shottky diode set up, got quite a few 5a animals but decided I did not want the voltage drop of 0.7v plus I would have to knock up a circuit board to mount them and make up fly leads, plug ins. I may do in the future but I have no issues at all. Spektrum Powersafe RX do not offer battery redundancy, still internally paralleled. Best and expensive option is Powerbox or similar.
Or of course I make my own powerbox up - regulator and fast switching battery monitor ;) Now there is a thing to do when it's raining.
8 years 7 months ago #12036 by
Hi Phil & Kevin.
Thank you both for your kind assistance, I am going to have a look at the switches that came with the model and see what I can do.
I am getting my head round this now :blush: :oops:
Simon
8 years 4 months ago - 8 years 4 months ago #13062 by
Hi Guy's
Help !!
Roto engine on the model i have bought from frank has a Walbro carb on it.
I have fitted the tank tubing as advised, set up linkage etc, etc, ready to start engine first run (it has never been run been in storage since 2014)
Got fuel in tank engine will not pull fuel up, disconnect fuel line from carb blow into vent pipe fuel supplied to carb pipe.
Put carb feed back on pressurise tank slightly no fuel to carb, take off carb pipe pressure to tank- fuel at carb.
Take off carb from engine, remove fuel feed pipe and cover blow in pipe ok, put cover back on can't blow through pipe.
Seems like the inlet of the carb is blocked, take out low and high speed jets still can't blow through ?
Any suggestions
Ta
Simon
Last edit: 8 years 4 months ago by .
Time to create page: 0.426 seconds
