AeroTech Pitts Python 50cc
7 years 1 month ago #17589 by JonTappin
Replied by JonTappin on topic AeroTech Pitts Python 50cc
Phil
I have used what sounds like the same stuff to baffle my 104 Extra, white gloss card with foam infill. Has worked perfectly, heat has not been an issue at all.
I used Gorilla glue to fix it, which has held up very well.
7 years 1 month ago #17591 by Phil Ford
I thought it might be the same stuff you used. It came out of a box a long time ago and I just kept it in the odds n sods drawer. I think it might have been the PC21 possibly. I will have a go with it then. Maybe paint some cylinders on it......;)
I assume you cut it to shape and use Gorilla where it touches the GRP cowl?
7 years 1 month ago #17593 by JonTappin
Yes, but I don't know how much you are cutting away, I would think you would need a reasonable amount of contact area, otherwise the vibration will loosen it fairly quickly
7 years 1 month ago - 7 years 1 month ago #17631 by Phil Ford
Slope soaring day tomorrow so spent today assembling the Pitts fully (as would have to be done at the field). A few niggles with the interplane strut bolts though. After the run up I then spent the afternoon cutting a slot in the lower cowl directly in front of the cylinder head. Unfortunately the air scoop can not be fitted. :( Exhaust had a slight blow (oil stains appearing) so cleaned up the mating surfaces and used high temp silicon copper to seal it. Throttle curve re-adjusted for a linear feel. Set up the elevators as they were not operating together - a few turns on the control rods sorted that out. Just the ailerons to check now.. Once I am happy with everything I will make up some wing wires for scale effect in the near future.
If you got 5 mins spare watch the video...;)
The following user(s) said Thank You: DaveBright, Brian
Time to create page: 0.270 seconds
