Cashmoor warbird fleet size increase
26 Jan 2019 19:35 #18816 by 4Pedalsfly
Replied by 4Pedalsfly on topic Cashmoor warbird fleet size increase
Kevin - Cannot find anything to help you out, hopefully you'll get sorted Monday.
29 Jan 2019 21:50 #18819 by kevinross
Replied by kevinross on topic Cashmoor warbird fleet size increase
kevinross wrote: Thought about compressing the lead and will post the solution
Now completed re-configuring the nose ballast. Made secondary stand-offs then mounted the weight on rubber bushes (in an attempt to minimise any vibration / resonance from the weight. This has improved the effective moment which will allow reducing the unnecessary 1.5 lbs battery weight which has a less effective moment.
The motor drive hub protrudes the cowl but this is compensated by a special spinner.
30 Jan 2019 07:48 - 30 Jan 2019 08:30 #18820 by JRI
Replied by JRI on topic Cashmoor warbird fleet size increase
A neat job Kevin, but I am convinced that you will also need diagonal cross-bracing between the top of each brass standoff and the bottom of an adjacent one, otherwise a resonant vibration in the weight could cause all of the load to be focused on the bottom of one of the brass standoffs causing the stud or the engine mounting lug to fracture.
I see it a bit like doing a dance on a slightly wobbly table, get the rhythm right and each gyration cumulatively adds to the motiion applied to the joints until one of the legs fails ! Diagonal cross-bracing limits the rocking motion (and potential twisting moments). Apparently the diagram below is how legged structures are made earthquake proof (presumably also allowing for some rocking movement to dissipate the energy).
Last edit: 30 Jan 2019 08:30 by JRI.
30 Jan 2019 10:12 - 30 Jan 2019 10:12 #18822 by kevinross
Diag bracing will be difficult. Need to re-assemble everything and run the engine to investigate.
Last edit: 30 Jan 2019 10:12 by kevinross.
01 Feb 2019 20:39 #18832 by 4Pedalsfly
Just spotted this for sale on the BMFA website - Vailly "Typhoon" powered by DA85.
Link to video below - before anyone asks - I will not be putting in a bid !
22 Mar 2019 10:26 #19145 by Phil Ford
Replied by Phil Ford on topic Cashmoor warbird fleet size increase
Kevin, before you put the Typhoon into the air you might want to watch this VERY interesting documentary of the Typhoon. You think you have problems! :lol:
In the end though the Typhoon would prove it's worth and rip up ground targets exceptionally well. Ugly looking thing though.
22 Mar 2019 11:24 #19147 by kevinross
Funny you should mention that member of the fleet - After many weeks of diversion for "Other Projects" its just returned to my workbench 1 hr ago
22 Mar 2019 12:49 #19148 by Phil Ford
kevinross wrote: Funny you should mention that member of the fleet - After many weeks of diversion for "Other Projects" its just returned to my workbench 1 hr ago
You thought we had forgotten??? :P
24 Mar 2019 22:33 #19184 by kevinross
Work progressing - The previous owner built the model using more channels than my DSX9 so i've had to combine some functions.
Landing lights -
Ive broken into the lights power and fitted micro switches on each flap servo operated by a disc fitted on the backside of the servo arm. They can be adjusted so that when the flaps are not fully retracted the port light switches on and when the flaps are > 50% the STBD light switches on. This will provide a visual indication of adverse flap setting.
24 Mar 2019 22:51 - 24 Mar 2019 22:54 #19185 by kevinross
Ive paralled the choke servo and Opto ignition switch
Operated by a 3 position switch, i've adjusted the geometry of the choke servo to provide
pos 1 - Choke ON - ignition OFF
pos 2 - Choke 90% ON - ignition ON
pos 3 - Choke OFF - ignition ON
Last edit: 24 Mar 2019 22:54 by kevinross.
Time to create page: 0.412 seconds
