Great Power 38
30 Sep 2021 08:15 #25191 by DavidTappin
Replied by DavidTappin on topic Great Power 38 Engine Help
Phil,
Have you tried running it straight off a supplementary fuel supply? Always possible it’s a blocked clunk or detached clunk tube. I had something like this when I converted a motor to petrol but forgot to substitute a tygon clunk tube, the old one had fallen off the copper outlet tube having sofened with the petrol and because I wasn't bothering to completely fill the tank just for a test run the fuel level was quite low - not reaching the outlet so the carb was just sucking air.
Just a thought.
  • Brian Jackson
30 Sep 2021 08:35 #25192 by Brian Jackson
Replied by Brian Jackson on topic Great Power 38
Had the dry plug problem with my leaf blower engine. Turned out to be a perforated pump diaphragm on the Walbro.
30 Sep 2021 11:18 - 30 Sep 2021 11:19 #25193 by Phil Ford
Replied by Phil Ford on topic Great Power 38 Engine Help
I actually did get it running momentarily but before I could adjust the RPM down and adjust the low needle it stopped. It did not start again even after loads of flips. maybe it is the reed block? This is a bad show considering the engine has had maybe a total of 90 mins flying time. AerobatX do have a reed block kit at £41.00. Surely I should not need this just yet? Or am I just throwing more dough at it and still not solving the problem? :unsure: At this rate of buying bits and getting nowhere I should swap it out for a DLE35
Last edit: 30 Sep 2021 11:19 by Phil Ford.
30 Sep 2021 13:22 #25194 by C.Morris
Replied by C.Morris on topic Great Power 38
I'm no expert, but from experience cracked or warped reeds can cause poor starting. Definitely worth checking them.
PS fancy fixing my DA60, it runs but poorly. Needle adjustment does nothing!!!! :lol:
30 Sep 2021 15:04 #25195 by Phil Ford
Chris Morris wrote: fancy fixing my DA60, it runs but poorly. Needle adjustment does nothing!!!! :lol:
Ah, that sounds like fuel regulator or metering what ever you wanna call it
30 Sep 2021 15:58 #25196 by C.Morris
:lol: :lol:
Have planned to strip the carb and clean ect.
Good luck with GP38!!
01 Oct 2021 08:43 #25197 by ruggerbloke
Replied by ruggerbloke on topic Great Power 38 Engine Help
Swap it Phil!
02 Oct 2021 14:20 #25198 by Phil Ford
I have checked the reed block and spacer to verify that the pulse can get to the carb body. Maybe the gaskets in between were leaking and reducing pulse pressure? Kevin is going to check over the carb in case I have missed something.
  • Brian Jackson
03 Oct 2021 08:32 #25200 by Brian Jackson
Just a thought Phil. The "new" petrol at the pumps has alcohol in it. I wondered if this could have affected the tube inside the fuel tank, swelling it and effectively closing the bore?
03 Oct 2021 10:20 #25203 by Phil Ford
Not fuel lines Brian. Carburetor issue or pulse issue. ie; flappers or there is a blockage in the carb body or I have overlooked something obvious. ;)
Time to create page: 0.356 seconds
