Great Power 38
03 Oct 2021 19:56 #25207 by JRI
Replied by JRI on topic Great Power 38
Not fuel lines Brian. Carburetor issue or pulse issue. ie; flappers or there is a blockage in the carb body or I have overlooked something obvious. ;)
Ignition !
04 Oct 2021 10:33 - 04 Oct 2021 10:39 #25211 by Phil Ford
Replied by Phil Ford on topic Great Power 38
No fuel John. Dry spark plug. Squirt some down the carb mouth and it will fire straight away.
Went over to Kevin's on Sunday for some testing Carb is fine. The HDA 246A carb appears to be designed especially for GP engines with an extra high jet for for fast opening of throttle. Crankcase has no air leaks. Reed block and reeds look a bit suspect. Two out of four are not fully closing. Have asked for advice on latter from Clive McInness at AerobatX. They keep GP engine spares unlike some others I won't mention.
Last edit: 04 Oct 2021 10:39 by Phil Ford.
04 Oct 2021 12:00 - 04 Oct 2021 12:01 #25212 by Phil Ford
Monday 4th - Check if fuel pump is actually working. Reassembled the carb and reed blocks and mounted on the engine. Clamped engine into my work bench. Removed spark plug, fit prop and spinner. Spin engine over and watch fuel moving up the line. Remove regulator cover and whilst spinning motor over depress needle valve. Fuel appears! :huh: That's a good sign.If weather holds off today I will refit the engine to the Extra and see what happens..........Images not necessarily in right order.. Kevin cleans up reeds and checks them with suck n blow. A cut down credit card bolted to reed block with an fuel line adaptor.
Last edit: 04 Oct 2021 12:01 by Phil Ford.
04 Oct 2021 13:09 - 04 Oct 2021 13:21 #25214 by Phil Ford
Engine refitted to airframe. Fueled up. Flick it over and fuel pulling in to engine. Choke on. Flipped a few times and no kick? Choke off, throttle a little open, flick and nothing. Remove plug. Flooded. Dry plug. Try again this time just throttle. KIcked once or twice and bouncing back on compression and then nothing.
I am at a loss here. I have had enough of this crap. I have spent around 8 hours over the past weeks on this. Take the flipping thing out and send it back under warranty. Should not be fannying about like this in the amount of runtime this engine has had.
Last edit: 04 Oct 2021 13:21 by Phil Ford.
  • Brian Jackson
04 Oct 2021 21:36 #25216 by Brian Jackson
Replied by Brian Jackson on topic Great Power 38
Before you give up completely Phil, have you tried a different spark plug? I read somewhere that a plug may spark OK in the open air, but fails under pressure.
05 Oct 2021 09:18 - 05 Oct 2021 13:28 #25217 by Phil Ford
Done that Brian a while ago. ;) Two things that have not been tested. 1. Kill switch 2. Try another ignition unit. Later today if weather holds off will bypass kill switch. Next swap the ignition unit with a DLE spare one and see if it fires up. (Note it may not perform the same as the ignition advance curve probably is not the same). I have now realised that although these GP engines are well made in Taiwan the back up of spares and knowledge is minimal except for two companies in the UK.
Last edit: 05 Oct 2021 13:28 by Phil Ford.
05 Oct 2021 13:30 #25221 by Phil Ford
Definitely a fuel issue. :( All other items checked.
05 Oct 2021 14:48 - 05 Oct 2021 14:49 #25223 by C.Morris
Replied by C.Morris on topic Great Power 38
I can stick it onto my test bed and have a tinka if you like?!!
Last edit: 05 Oct 2021 14:49 by C.Morris.
05 Oct 2021 18:48 - 05 Oct 2021 19:02 #25224 by kevinross
Replied by kevinross on topic Great Power 38
Hi Chris - As you will have read ive also looked at Phils motor so your fresh view might be a good idea. Phil is in two minds as to put the motor with Probuild or let the AerobatX look at it.
Just to review what i have done.
Leak tested crankcase (for bearing seal leak)
verified the pump works (by removing the fuel chamber cover and releasing the regulator plunger) which Phil has also carried out on his bench.
The reed block is quite a lightweight plastic structure and the reed petal mount screws had distorted the mounting point. Ive tried the flatten that distortion. The petals don't close absolutely but I dont think sufficient to prevent running.
Using a pippet ended tube, I've blown thru the idle and main jets feeds and verified the flow changes with needle adjustment.
This carb has a sprung ball valve preceding the main jet outlet which i assume opens to release a pulse neat fuel when the butterfly is opened rapidly. I know it opens because I've trickled neat fuel on the inside. when I pushed the ball with a needle point the fuel runs into the venturi. HOWEVER, IF THIS DOES NOT CLOSE IN REVERSE IT WILL ALLOW AIR TO FLOW BACK INTO THE FUEL CHAMBER AND VENT ALL THE FUEL.
Last edit: 05 Oct 2021 19:02 by Phil Ford.
05 Oct 2021 18:59 #25225 by Phil Ford
Hi Chris. another set of eyes over it would be great. Nearly two months now since it stopped running. I will email you to arrange. Thanks. An update today 5th October. Neat fuel down carb mouth and it fires up momentarily.
Time to create page: 0.335 seconds
