CAP232 Breitling
  • Stuartmck
16 Jun 2015 14:55 #4887 by Stuartmck
Replied by Stuartmck on topic CAP232 Breitling
Hope you have a drill jig for DLE, If not,believe mine fits 30 and 55. you may borrow if required.
Stuart
16 Jun 2015 23:46 #4897 by DavidTappin
Replied by DavidTappin on topic CAP232 Breitling
Phil wrote
I am unable to drive anywhere myself
And my pillar drill weighs about 2 cwt so I fear that there is no chance of bringing it to you.
17 Jun 2015 10:21 - 17 Jun 2015 10:28 #4898 by Phil Ford
CWT? Have'nt heard that term since 1974..... :lol:
Thanks Guys for replies. I had already ordered a jig for the DLE 30 thro to 55 (It fits other engines too, DA and AGM) as a useful addition to the tool box and also be able to set-up future props.
On Tuesday, whilst pondering where the hell are the RX batteries gonna go and there was only one feasible option I had have to strip out the servo wiring and AR9110 powerbus and reposition. Then cut out a battery/RX tray and make to fit. Rewire or re-route leads, etc.
Then the hardest part was squeezing myself into the cockpit and putting on the helmet.... :lol:
Last edit: 17 Jun 2015 10:28 by Phil Ford.
17 Jun 2015 12:52 #4905 by DavidTappin
FYI "about 2 CWT" means exactly 101.60469 Kilograms but in any language it hurts if you drop it on your foot, you don't need to ask how I know that.
17 Jun 2015 13:32 #4908 by Phil Ford
101.60469 Kilograms - That will hurt. :lol:
17 Jun 2015 19:28 #4918 by Phil Ford
Added more ply to cowl fixing points. This is to allow me to use 4mm spike nuts. The cowl will then be secured using 4mm cap head screws with rubber-backed washers.
Finally screwed pilot to cockpit floor and stuck down the canopy.
17 Jun 2015 19:49 #4919 by flyingpete
Really starting to look the dogs b______s Phil!
I used to have a 40% cap 232 with a zdz 160, biggest mistake of my life selling it,still trying to buy it back after 6 years of selling her :angry:
18 Jun 2015 08:39 - 18 Jun 2015 08:44 #4921 by Phil Ford
flyingpete wrote: I used to have a 40% cap 232 with a zdz 160, biggest mistake of my life selling it,still trying to buy it back after 6 years of selling her :angry:
You missed out the letters "o l l o c k" Pete! :lol:
There are a lot of 40% Carden Caps still around mainly in States though.
I have enjoyed putting and modifying this CAP and it has saved me from weeks of boredom. Although it has been a bit of a plod as all my numerous other models did not use HD stuff, so had to buy more accessories in. Hoping to run up engine shortly and soon as I am able to get her outside, (it can't live in kitchen much longer :unsure: ) fit wings and see what's needed to balance it.
The next bit should be interesting...............Where the hell I am going to store it. Does it fit into an Astravan? :lol:
Last edit: 18 Jun 2015 08:44 by Phil Ford.
19 Jun 2015 18:10 - 19 Jun 2015 18:12 #4949 by Phil Ford
Busy morning and early afternoon with health care stuff. That left most of the afternoon free. Drilled out prop using a DLE jig and fitted it to engine.
Couldn't resist temptation so got my wife to assist me. CAP in drive, fuelled up, power on, ign on and wife's legs as restraint. Flicking and flicking to avail. :( Dry carb? Pulled off carb line and pressurised the system by blowing back through the vent line till gas ran out. Reconnected line and after a few more flicks it kicked. Flicked again and engine running for just a couple of minutes then wife complained about dents in her legs from the stabiliser. :lol: Cut motor. Re-torqued exhaust bolts.
Really pleased it is coming together. A few small tweaks and spark plug lead routing and secure.
Just got to find a suitable 3.5 inch spinner that will take large wide blade props. Also possibly some large ally servo arms for Hitec servos on elevators.
Last edit: 19 Jun 2015 18:12 by Phil Ford.
19 Jun 2015 18:48 #4950 by JonTappin
Phil
I really like the irvine spinners, lightened ally backplate and plastic cone, easy to trim nice quality and relatively cheap, I have one on my 88 Edge, various colours available. 89mm should do you.
www.wheelspinmodels.co.uk/c/244/?cs=%7B1%3A%5B116%5D%7D
for metal servo arms, Secraft ones are nice, avaliable from MacGregor, Hobbyplastic
Time to create page: 0.416 seconds
