CAP232 Breitling
19 Jun 2015 19:28 - 19 Jun 2015 19:29 #4953 by Phil Ford
Cheers Jon. Just had an order from Hobbyplastic for some Secraft deluxe wing bolts. I never noticed those servo arms further down the accessories page. Oh well, it can wait till Monday/Tuesday to order 1 inch metals. That'll give me one to one pull ratio.
I like Irvine too, have used them for sometime but I did not think there was enough metal on their lightened backplates to drill out for 4 bolt prop drive. I'll have to have a rummage thro my stock. :lol: Your right, 3 1/2 inch spinner 89/90mm is the size I am looking at to fit. Tru-Turn are nice , expensive and Probuild have not got any in my size.
Last edit: 19 Jun 2015 19:29 by Phil Ford.
19 Jun 2015 21:16 #4956 by JonTappin
There's plenty of meat in the backplate for 4 bolts, my MVVS is 6 bolt and that's fine.
23 Jun 2015 14:20 - 23 Jun 2015 14:23 #4982 by Phil Ford
Two 89mm spinners turned up today. A black and a red one. The Red was not a bright arterial red as I thought so hacked away at the black. Seemed like all morning nibbling away but finally and after some adjustment to the 4 mounting holes in the backplate - Presto. Pity the prop ain't black but the spinner looks like it is supposed to be there and at scale or thereabouts.
Thanks Jon for pointing me in the right item. ;) Really pleased
Servo arms. I'll stick to the Hitec HD plastic ones for now seeing as the surfaces are all set up.
Last edit: 23 Jun 2015 14:23 by Phil Ford.
23 Jun 2015 17:19 #4983 by DavidTappin
Replied by DavidTappin on topic CAP232 Breitling
You don't need permission to paint the prop black Phil, to scale the back of the blades would probably be black anyway.
23 Jun 2015 18:49 #4985 by Phil Ford
:lol: Okay then. Should I just prime it lightly with dark grey and followed up with satin black acrylic car aerosol. I suppose I should lightly wet n dry the varnish surface first.
24 Jun 2015 19:03 #4990 by Phil Ford
With some difficulty managed to get it out of the kitchen and into the drive so I could attach the wings and check C of G. I think it is a little tail heavy but I could not hold it for long enough. When I am more fit-n-able I'll have another go... ;) No rush anyway because it won't fit the van ... :(
25 Jun 2015 09:53 #4994 by DaveBright
Looks good Phil
25 Jun 2015 10:48 #4995 by DavidTappin
That's a shame it looks so good - but don't despair - I can help you out, it'll go in my car ok, you better give it to me!
25 Jun 2015 13:33 #4997 by JonTappin
Very pretty Phil :)
What's the plan for transportation then?
25 Jun 2015 17:04 #4998 by DaveBright
Are the tailplanes removable? If not, I came up with a quick connect solution to this some years back :-)
Time to create page: 0.393 seconds
