Sabres and Migs and stuff
13 Sep 2014 22:57 #2983 by DaveBright
Replied by DaveBright on topic Sabres and Migs and stuff
AlanF wrote:
simondean wrote: As far as throws are concerned I once asked that very question and the reply I got from a very respected club member was UP a BIT and DOWN a BIT so I should just take a good guess !!
Sound advice thanks Simon, I've got some up and down and 5 sets of rates with assorted throws and expo and a pmix on a slider to add some more up or down and flight conditions to add some more of what I haven't got and its all linked to some switches which I will never find when I'm in a panic - so I'm sorted :cheer:
  • AlanF
26 Sep 2014 22:10 #3082 by AlanF
Mr Rogers, it's all gone quiet on the Phazer front, have you maidened/destroyed yours yet? are you flying on Sunday, is it going to to to be a mass launch of one Phazer, whats happening?
27 Sep 2014 09:27 #3085 by Dave Rogers
Replied by Dave Rogers on topic Sabres and Migs and stuff
Yes I will be there Sunday with phaser, it will be its first flight, I've actually fitted the wheels so gonna try them first then pull them off after as they detach real easy!
Are there going to be many jets (turbines) there on Sunday? I can always bring the avonds f15 for display if not, but it does have a very gay colour scheme so no innuendos please, I will eventually be resprayed
  • Phil-C
27 Sep 2014 09:30 #3086 by Phil-C
Replied by Phil-C on topic Sabres and Migs and stuff
Dave said "I will eventually be resprayed"
What colour scheme are you planning Dave? Will the accessories be colour coordinated?
  • AlanF
27 Sep 2014 11:55 #3087 by AlanF
Dave Rogers wrote: Yes I will be there Sunday with phaser, it will be its first flight, I've actually fitted the wheels so gonna try them first then pull them off after as they detach real easy!
I've discovered that there are many things that detach real easy from the Pazer eg the canopy, lipo , ESC, Rx but it all goes back together easily enough if you can find the bits :blush:
Careful with the respray, I would avoid rubbing down between coats ;) See you tomorrow.
27 Sep 2014 18:01 #3088 by DavidTappin
Replied by DavidTappin on topic Sabres and Migs and stuff
The only turbine I'm sure of is my Boomerang, Screwlock Dave is going to bring his new huge Hawk for static display so it would be nice to have your F-15 along too.
28 Sep 2014 09:25 #3092 by DaveBright
Does anyone desperately need the dolly I promised....as I have forgotten to pack it!! Let me know ASAP as I can detour past the hangar to pick it up
  • AlanF
28 Sep 2014 18:50 #3093 by AlanF
DaveR , What's your thoughts on the Phazer now you've flown it? You were right about the servos - I've lost about 180 degrees worth of teeth on one elevon servo and it was only a little crash!
DaveB is you're Dolly inflatable - just asking.
  • AlanF
01 Oct 2014 23:35 - 01 Oct 2014 23:37 #3103 by AlanF
Trashed servos on the Phazer now replaced with Turnigy 9g MG jobbies ( 3 quid each from HK and a vast improvement in performance). Dinged and bent wing tips straightened using the old boiling water trick ( works like a charm). Melted velcro fastener for the ESC replaced with garden twine ( not sure about this but short of using fire cement I don't know what else to do). So we're ready for the next bout of carnage :cheer:
Last edit: 01 Oct 2014 23:37 by AlanF.
Time to create page: 0.327 seconds
