BVM Mig.15
19 Jan 2017 08:13 #11600 by DavidTappin
Replied by DavidTappin on topic BVM Mig.15
Pete, so sorry to hear your sad news, I've PM'd you
20 Jan 2017 12:05 #11620 by flyingpete
Some pictures of the fitting of the tailpipe from last weekend. First job was to cut the tailpipe to the shape of the rear fuzz and fit the strengthening ring. Four maple blocks glued in, to hold the pipe in position.
20 Jan 2017 12:07 #11621 by flyingpete
Few more
20 Jan 2017 12:24 #11623 by JonTappin
Replied by JonTappin on topic BVM Mig.15
Very tidy! B)
20 Jan 2017 13:45 #11624 by flyingpete
To protect the speed brake servos from heat I have wrapped another ceramic blanket around the tailpipe in their location. To secure I have used carbon tow wraps soaked in thin can.
20 Jan 2017 14:08 - 20 Jan 2017 14:15 #11625 by flyingpete
Inner and outer tailpipe's fitted together, note the inner pipe is set back 25mm from the outer pipe as per the BVM instructions. On the turbine end, I have set inner pipe back 30mm from the cone as per the norm. This measurement is quite critical as too close to the turbine tail cone and it will suffocate the turbine and restrict power. If its too far away you run the risk of not collecting all the heat and flames from the turbine and in nanno seconds the model will be a fire ball.
In the last pick you can see the heat blanket through the speed brake aperture.
I will show details of the turbine installation when I get back on the mig over the weekend.
Last edit: 20 Jan 2017 14:15 by flyingpete.
20 Jan 2017 16:17 #11626 by kevinross
Replied by kevinross on topic BVM Mig.15
Your a man of many talents Pete - For a chippy you also demonstrate excellent blacksmith skills by trimming that SS tailpipe beautifully.
20 Jan 2017 19:35 #11632 by flyingpete
Tanks finished and ready to fit, the black bracket on the main tank is to secure it to the fuzz bottom, the total capacity of the three tanks is 3ltrs.
21 Jan 2017 11:13 #11635 by flyingpete
Morning Guys, Time to move on and get back on the Mig, so Its time to trial fit the hardware into the fuzz, a series of pictures will show the fit out.
21 Jan 2017 11:15 #11636 by flyingpete
Pics
Time to create page: 0.726 seconds
