BVM Mig.15
8 years 8 months ago #11512 by flyingpete
As I have the fuzz on the bench a good time to cut the cooling slots on the bottom of the wing fillet. Marked the slots using the paper template, stitch drill and Cleaned up using flat and round files.
8 years 8 months ago #11513 by flyingpete
Rear Aluminium heat shield fitted
8 years 8 months ago #11515 by Phil Ford
Well BVM! You cannot supply the paint codes? Because the colour was just randomly sourced? If they were really interested they could give John the manufacturer contact info who "might" be willing to give the colour codes used to make the mixes with known paint makers here.
If only a small quantity, for instance two aerosol cans worth, (approx 500ml would it not be a problem for shipment by the men in brown or DHL. :unsure:
Of course you could take a sample to the local Uni and get them to Spectrum Analyse it. :lol:
8 years 8 months ago #11516 by flyingpete
Yes it's a shame John can't source from BVM, especially when I only need a very small amount as I will be using it in a air brush.
8 years 8 months ago #11517 by Phil Ford
flyingpete wrote: Yes it's a shame John can't source from BVM, especially when I only need a very small amount as I will be using it in a air brush.
So, what options left? Trial n Error with acrylics? White, grey and blue. The Sand colour would be easier to match surely. :unsure:
8 years 8 months ago #11523 by flyingpete
Turbine by-pass ready to fit in the fuzz, mounting lugs reinforced with 1/4 ply. I have drilled a 1/8 hole in the bottom to allow fuel to drain out incase of a spillage or leak.
Time to create page: 0.363 seconds
