Stearman build
1 year 6 months ago #26752 by kevinross
This week ive worked on the Stab / fin rigging, which like everything else ive tried to have a resemblance to the full size. - Attached some detail from the Stearman manual
1 year 6 months ago - 1 year 6 months ago #26753 by kevinross
Ive previously covered the swivels (some years ago)
Ive reduced to clevis lengths by annealing , re-drilling using a jig, cutting off and re-shaping.
The rigging wires are terminated by silver soldering an M2 screw to fit the clevis using SS band from Mick Reeves models
I will upgrade the panel pins with proper nuts and bolts
Last edit: 1 year 6 months ago by kevinross.
1 year 6 months ago #26758 by kevinross
 A few interruptions by the head gardener this week but finally silver brazed all the rigging straps. Fabrication started by sawing the full depth of a cheese head M2 screw and a V slot ground in the strap. Flux applied and screw inserted into 2mm hole in a fire brick for brazing.
1 year 5 months ago #26772 by kevinross
Let minute decision to fit nav lights so upper wing tips modified (comparison with lower tip)
1 year 5 months ago #26775 by kevinross
I hope these Nav lights show well in flight
1 year 5 months ago #26776 by kevinross
Decided not to use covering film on the centre section so it's been glassed. Also the small ABS parts to provide a bit more strength (they were probably moulded 15yrs ago )
After 4 yrs i cant believe there is one part ready for paint !
