Stearman build
12 Feb 2024 12:35 #26729 by Phil Ford
Coming on slowly Kevin.  Thought you had forgotten it, last post 10 months ago.
13 Feb 2024 11:34 #26730 by kevinross
a few hours of filling and sanding later
13 Feb 2024 13:48 - 13 Feb 2024 13:49 #26731 by 4Pedalsfly
Replied by 4Pedalsfly on topic Stearman build
Hi Kevin - Good to see Stearman is back on the bench.
Look forward to seeing the  progress.
My " longest" build was 15 years, Spit from a plan.
Catch up soon.
Last edit: 13 Feb 2024 13:49 by 4Pedalsfly. Reason: Error
15 Feb 2024 17:46 #26735 by kevinross
Considered how i would attach the windscreens after painting so come up with this effective solution.
1. lay up some glass cloth on a backing sheet to match the fuselage profile
2. Bond the windshields to the moulding and finish to size - they can then be painted off the model
3. II'll make some predefined locations so they can be cleanly fixed after painting
15 Feb 2024 17:47 #26736 by kevinross
windshields continued
16 Feb 2024 21:57 #26743 by kevinross
Undercarriage - ABS fairings trimmed to shape - Leg fairings fabricated with a bit more ply steaming and shaping
The following user(s) said Thank You: 4Pedalsfly, DavidTappin
25 Feb 2024 18:29 #26752 by kevinross
This week ive worked on the Stab / fin rigging, which like everything else ive tried to have a resemblance to the full size. - Attached some detail from the Stearman manual
25 Feb 2024 18:35 - 25 Feb 2024 18:36 #26753 by kevinross
Ive previously covered the swivels (some years ago)
Ive reduced to clevis lengths by annealing , re-drilling using a jig, cutting off and re-shaping.
The rigging wires are terminated by silver soldering an M2 screw to fit the clevis using SS band from Mick Reeves models
I will upgrade the panel pins with proper nuts and bolts
Last edit: 25 Feb 2024 18:36 by kevinross.
04 Mar 2024 21:49 #26758 by kevinross
 A few interruptions by the head gardener this week but finally silver brazed all the rigging straps. Fabrication started by sawing the full depth of a cheese head M2 screw and a V slot ground in the strap. Flux applied and screw inserted into 2mm hole in a fire brick for brazing.
19 Mar 2024 14:26 #26772 by kevinross
Let minute decision to fit nav lights so upper wing tips modified (comparison with lower tip)
Time to create page: 0.424 seconds
