Stearman build
1 year 3 months ago - 1 year 3 months ago #26819 by kevinross
Eventually got around to laying up the cowl and spats using the mould I made  a year ago. Bending the shaft on this oval roller was a bit help.
I made a balsa ring to reinforce the frontal radius to minimise the amount of resin and weight.
Last edit: 1 year 3 months ago by Phil Ford.
1 year 3 months ago #26820 by kevinross
Sheer brutality was the only way to split the mould but at last i have a cowl
1 year 3 months ago #26821 by Phil Ford
A hell of a lot of work Kevin to achieve the basic cowl, etc.
I wonder if someone has a mould laying around gathering dust somewhere in the world that may have saved you some time.
1 year 3 months ago - 1 year 3 months ago #26824 by kevinross
The concept seemed quite straightforward 4 yrs ago - How naive i was
Amy way here is the initial placing / fitting of the forward cowl . I had to produce a built it "spider" to interface the two parts
All being well my nephew is producing a 9 cylinder 3D printed dummy engine
Last edit: 1 year 3 months ago by kevinross.
1 year 3 months ago #26826 by Phil Ford
Certainly been a major project Kevin, surprised you have stuck at it.   There are full  kits and there are kits and make the rest up as you go along.  No wonder ARFs are popular!
1 year 1 month ago #26863 by kevinross
Having previously moulded the outer shells for the spats, i need an inner pair with flats to assist mounting to the U/C leg adapters.
I poured an equal volume of epoxy & micro balloons into each mould then layered the inner sections
After trimming the edges i fixed small balsa teeth alternatly to aid alignment. They are now fixed with cyan to enable me to join with glass bandage
