Mk 11C Hurricane winter build
10 years 9 months ago #3422 by DavidTappin
Replied by DavidTappin on topic Mk 11C Hurricane winter build
Jon said
I have a feeling I might need to give this one a more detailed over 50cc assessment than usual, including in flight assessment
Frankly I wouldn't let him near it, just look at what he did to my Impressivo......
10 years 9 months ago #3424 by MikeSeale
Replied by MikeSeale on topic Mk 11C Hurricane winter build
I've seen worse!
  • Banned
  • Banned
10 years 9 months ago #3425 by flyingpete
Replied by flyingpete on topic Mk 11C Hurricane winter build
LOL
  • Banned
  • Banned
10 years 9 months ago - 10 years 9 months ago #3431 by flyingpete
Just been looking at the possibilty of scale working exhaust's for the hurricane and found some drawings for them B) .Think i will have a crack at them when the time comes.Also been looking at rivet and panel detail,and i think i will go with the mick reeves system of stick on, as there are 1000's of them :ohmy: and 1/16 tape and high build primer for the panel lines. The airframe will be covered in tex and 3 coats of thinned shrinking dope to stop the dreaded sag and 2 pac paint to finish.
Last edit: 10 years 9 months ago by flyingpete. Reason: text
  • Banned
  • Banned
10 years 9 months ago #3444 by flyingpete
Ok chap's,hope you had a good christmas B) Right hand outer wing panel uderway
  • Banned
  • Banned
10 years 9 months ago - 10 years 9 months ago #3445 by flyingpete
Right hand panel glued to centre section.In the second picture you will see that i have left a 3/32 gap between the 2 ply ribs in the middle section of the wing tube on the right hand panel so after sheeting the top surface it will act as a guide for a hack saw blade to cut through the wing joiner and spars to make a 3 piece wing after doing the same with the left hand outer panel.You could i suppose sheet the wing in 3 separate panels but doing it the way i have, will make sure everything stays inline,the last thing you need is a badly fitting wing joint on the wing tubes.
Time to create page: 0.279 seconds
