Mk 11C Hurricane winter build
10 Jan 2015 08:36 #3505 by flyingpete
Replied by flyingpete on topic Mk 11C Hurricane winter build
Wing farings underway
22 Jan 2015 17:08 #3574 by flyingpete
The airframe is covered in tex so time to do some panel lines on the fuzz. I have drawn the panels and then cut some solar tex and over lap to simulate the panels so when the paint is on they will show through
23 Jan 2015 16:03 #3599 by flyingpete
Starting to look like a hurricane
23 Jan 2015 16:14 #3600 by flyingpete
Only another 2000 rivet heads to go :woohoo:
23 Jan 2015 17:43 #3601 by JonTappin
Replied by JonTappin on topic Mk 11C Hurricane winter build
Looking great Pete B)
What is that you are using for the rivet heads?
24 Jan 2015 16:53 #3609 by flyingpete
Jon,the rivet heads are 2mm half round resin beads stuck on individualy with minute blobs of pva.For the panel lines it's 1mm tape which will show through the pain't finish.
25 Jan 2015 12:12 - 25 Jan 2015 12:14 #3614 by Dante
Replied by Dante on topic Mk 11C Hurricane winter build
Terrific Pete, I'd be crosseyed after the first hour, but what a WOW effect you achieve.
Last edit: 25 Jan 2015 12:14 by Dante.
25 Jan 2015 14:25 #3616 by flyingpete
Thanks Dante,I was a bit tired when I went too bed last night after 12 hours of glueing the rivet heads on.I hope to get the primer on tomorrow and then fit her out with radio etc.It is my intention to get the hurricane up the field for Jon to inspect and hopefully give me the ok and I will test fly whilst it is still in primer.
Pete
27 Jan 2015 12:18 #3634 by flyingpete
Managed to get some primer on the airframe
27 Jan 2015 16:11 #3639 by Dave Rogers
Replied by Dave Rogers on topic Mk 11C Hurricane winter build
Wow! Looks brilliant, well done
Time to create page: 0.391 seconds
