DH VAMPIRE
  • Banned
  • Banned
10 years 1 month ago #5217 by flyingpete
DavidTappin wrote: Pete wrote
then on with the next stage
Judging by that ....285JPG image you may need to saw off that fin first, it's in completely the wrong place!
David, I'm sure the fin.is in the correct position :silly:
  • Banned
  • Banned
10 years 1 month ago #5222 by flyingpete
Had a couple of hours on the vampire today in between grandpops duty.The fuselage had a light sand and removed internal bracing. Glued in the nosegear bearers and strengthening pieces hardwood mounts for the turbine, tank tray and front tray for nosewheel servo, rx and batteries.
Also glued in the ply reinforcement for the front and rear dihedral braces.
10 years 1 month ago #5224 by DaveBright
Starting to take shape! Looking great
  • Banned
  • Banned
10 years 1 month ago #5230 by flyingpete
Sheeted fuselage wing root area and glued wing joiner ply tongues to inner wing panels only at this stage and trial fit inner panels so we have a nice close fitting joint.
These panels will be glued in place after I have finished fitting undercarriage, flaps etc,also it is easier to move the fuselage around without them as the vampire is 4ft wide with the on.
10 years 1 month ago #5231 by DavidTappin
Staggering progress pete, don't you ever sleep?
  • Banned
  • Banned
10 years 1 month ago #5232 by flyingpete
The rear former F12 is drilled out and sanded to shape to allow the thrust pipe to exit.
Time to create page: 0.281 seconds
