DH VAMPIRE
19 Jul 2015 20:08 #5192 by flyingpete
PhilF51 wrote: Progressing well Pete. Starting to look like something recognisable.... :lol: Albiet at present stood upright it would like Jules Verne's dream rocket :silly:
I was wondering who would be the first to say it looked more like a boat or rocket or something!
19 Jul 2015 20:11 #5193 by flyingpete
4Pedalsfly wrote: Pete - Impressive build so far, set of fuselage plywood formers ( 759 jpeg ) did you cut them yourself , or were
they laser cut ?
Colin.A.
Colin, it would be some sort of torture cutting all the slots for the stringers :ohmy:
19 Jul 2015 20:22 #5194 by flyingpete
Had a good afternoon strip sheeting the fuselage bottom. It was a bit challenging at times as the 1/8 balsa sheet is a tad too hard and not very forgiving so I reduced the plank width from 5/8 down to 1/2 and sprayed it with water to soften it,much better.
20 Jul 2015 17:14 - 20 Jul 2015 17:15 #5207 by flyingpete
Plenty of room for the turbine, fuel tanks and radio
Last edit: 20 Jul 2015 17:15 by flyingpete. Reason: Pics
20 Jul 2015 20:12 #5209 by flyingpete
Fuselage planking complete, leave to dry overnight and tidy up edges,give the fuselage a good sand and then on with the next stage.
20 Jul 2015 23:50 #5214 by DavidTappin
Judging by that ....285JPG image you may need to saw off that fin first, it's in completely the wrong place!
21 Jul 2015 08:42 #5217 by flyingpete
David, I'm sure the fin.is in the correct position :silly:
21 Jul 2015 16:32 #5222 by flyingpete
Had a couple of hours on the vampire today in between grandpops duty.The fuselage had a light sand and removed internal bracing. Glued in the nosegear bearers and strengthening pieces hardwood mounts for the turbine, tank tray and front tray for nosewheel servo, rx and batteries.
Also glued in the ply reinforcement for the front and rear dihedral braces.
21 Jul 2015 18:36 #5224 by DaveBright
Starting to take shape! Looking great
22 Jul 2015 13:51 #5230 by flyingpete
Sheeted fuselage wing root area and glued wing joiner ply tongues to inner wing panels only at this stage and trial fit inner panels so we have a nice close fitting joint.
These panels will be glued in place after I have finished fitting undercarriage, flaps etc,also it is easier to move the fuselage around without them as the vampire is 4ft wide with the on.
Time to create page: 2.889 seconds
