DH VAMPIRE
  • Banned
  • Banned
10 years 1 month ago #5259 by flyingpete
OK then! Port and starboard inner wings have all the strengthening added.End grain balsa shear webbs to front and rear spars solid balsa block around the wing dihedral brace.Thin f/g sheet added to undercarriage Bay to add strength after the rib has been removed. I also added some.support to the wing tube socket and mixed some micro balloons with epoxy to form a fillet and leading edge added.The wing will now be sheeted and air brake,flaps and wheel wells cut and epoxy undercarriage mounts.
  • Banned
  • Banned
10 years 1 month ago #5277 by flyingpete
Constructed outer flaps and air brakes.Note the trailing edge drops away with the flap.As the trailing edge is sanded down to fine edge I am going to add spruce strip to add strength and avoid warping. Pictures show surfaces fully deployed.
10 years 1 month ago #5279 by DavidTappin
Pete, what hinges are you using on the airbrakes? When those panels deploy at 100 mph there will be quite a pull on the hinges and with the worst case of one breaking away it would take a better pilot than me to recognise what had happened and take defensive action before loss of control ensued. I believe that was how Kerry Sterner lost his 1/4 scale version!
  • Banned
  • Banned
10 years 1 month ago #5280 by flyingpete
I'm planning on using heavy duty robarts buried into balsa blocks, they ain't going nowhere David
  • Banned
  • Banned
10 years 1 month ago #5285 by flyingpete
U/C bay's cut out,hardwood bearers going in with some balsa strengthening.
A note to rookie builders,as with any u/c mounts they need to be fairly solid but they need to rip out on a very hard landing as to not take the wing structure with it.I would also recommend not to bolt retracts in but use good quality self tappers.
  • Banned
  • Banned
10 years 1 month ago #5287 by flyingpete
Trial fit of u/c leg
Time to create page: 0.277 seconds
