Angel dust
26 Jul 2015 20:32 #5309 by Chris001
Replied by Chris001 on topic Angel dust
ummm.... any updates Mike? Five days left till the end of July you know :whistle:
26 Jul 2015 23:23 #5311 by MikeSeale
Replied by MikeSeale on topic Angel dust
Fuselage is now basically complete and rough sanded. It took a lot longer than expected due to all the head-scratching before gluing anything in place. This plan is a copy of the one that would have come with the MK kit back in the 1970's and whilst it shows you where to glue everything, it doesn't necessarily show you what shape each piece should be. I'm also aware that the kits back then were seriously over-engineered and I'm trying to reduce weight where I can. We'll see if I was successful when it's done.
I'll make a start on the wing tomorrow.
27 Jul 2015 20:44 - 27 Jul 2015 20:47 #5321 by flyingpete
Replied by flyingpete on topic Angel dust
Mike,your workshop is far too tidy :ohmy:
Last edit: 27 Jul 2015 20:47 by flyingpete. Reason: text
27 Jul 2015 22:28 #5323 by MikeSeale
flyingpete wrote: Mike,your workshop is far too tidy :ohmy:
15 minutes before that photo was taken it was not so tidy. And here's a pic looking the other way today.
As for the build...not a lot to show but I cut templates and then a foam wing. Tomorrow it's mounting the retracts and servos into the wing, and suitable tunnels for their servo leads before skinning.
28 Jul 2015 12:41 #5327 by Phil Ford
Replied by Phil Ford on topic Angel dust
I was going to mention that too Pete! And space under the worktop, WOW! ;)
28 Jul 2015 22:02 #5339 by MikeSeale
Four skins...
...two left and two right, ready for sanding
28 Jul 2015 22:10 #5340 by MikeSeale
Most of the work today was on the foam cores. Cutouts were made for the retracts and aileron servos. After cutting the sides with a sharp scalpel I used a sanding drum on my dremel to cut into the foam. Dremel in one hand and the workshop vac in the other...saves a lot of mess.
The mounting plate for the retracts has 4 dowels epoxied into the foam. These are angled like a saw-horse and will hopefully spread the load on those heavy landings.
I also cut channels for the servo leads. I decided to make them big enough to take the large connector on the end of an extension lead so I can easily swap servos and retracts if necessary.
Tomorrow it's wing skinning time and fin construction...
29 Jul 2015 23:01 #5351 by MikeSeale
First job of the day was to lightly sand the wing skins...much easier to sand before you glue them to a curved wing. Then it was time to glue the skins on using Gorilla glue. This is when I spread the glue onto the freshly sanded surface instead of the unsanded side :oops: After spreading the glue the skins are added and the wings are placed back in their offcuts, then taped and weighted down for a few hours while the polyurethane glue foams and dries. Compared to contact adhesive or epoxy, this is a much cleaner and easier glue to work with.
The base of the fin was tack glued in place and rough carved. The fin itself is drying.
The wheel wells are lined and leading and trailing edges are added.
01 Aug 2015 01:05 #5360 by MikeSeale
I've made a bit more progress and will upload a few photos in the morning. But more importantly, I went flying this afternoon and apparently "I've gone up in Franks estimation", due to the fact that I've cut my own cores. I'm not sure where the baseline was, so I don't know if this means I'm just hovering above the gutter now or if I'm right up there on a pedestal. But high praise indeed. Thank you, Frank
01 Aug 2015 08:07 #5361 by DaveBright
Replied by DaveBright on topic Angel dust
Oh dear, that does not bode well for me!
Time to create page: 0.427 seconds
