Angel dust
  • FrankRobinson
01 Aug 2015 15:17 #5363 by FrankRobinson
Replied by FrankRobinson on topic Angel dust
Cutting out your own wings in foam is above putting wings together from laser cut parts this is in the top echelon of airo modelers getting them true can give you good problems, well done Mike, theres hope for you yet Dave :ohmy:
10 Aug 2015 22:21 #5503 by MikeSeale
Replied by MikeSeale on topic Angel dust
The build has not stopped, although it has slowed a lot. A few photos showing the wing under-belly tack-glued in place and sanded to shape. The fin is also tacked on and sanded to shape. Wing is joined and the centre-section is reinforced with glass.
10 Aug 2015 22:23 #5504 by MikeSeale
...and my little helpers, Charlie and Holly, showing that the nose retract is now installed
11 Aug 2015 11:34 #5505 by JonTappin
Replied by JonTappin on topic Angel dust
The F3a worlds are going on as we speak, I found these photos on the official website, they have done an exhibit of the history of F3a
11 Aug 2015 18:48 #5509 by MikeSeale
Thanks for that, Jon. I hope my Blue Angel will look this good.
11 Aug 2015 20:13 #5510 by JonTappin
Really like the scheme on it, wouldn't be too hard to reproduce
11 Aug 2015 22:29 #5511 by 4Pedalsfly
Replied by 4Pedalsfly on topic Angel dust
MikeSeale wrote: Thanks for that, Jon. I hope my Blue Angel will look this good.
Mike - Sleek looking machine - what power setup will you be using ? Look forward to seeing it knife edging
along the strip .
Colin. A
11 Aug 2015 23:00 #5512 by MikeSeale
JonTappin wrote: Really like the scheme on it, wouldn't be too hard to reproduce
That's the only colour scheme to do. Attached is a photo of the oringinal
11 Aug 2015 23:22 #5513 by MikeSeale
4Pedalsfly wrote: what power setup will you be using ?
I'm planning to use the same motor that Chris has in his electric Wot 4...a Turnigy 5045 660kv . Depending on weight, I'll probably use a Zippy 4000 40C spinning something in the 11x7 to 11x9 range.
11 Aug 2015 23:25 - 11 Aug 2015 23:25 #5514 by DaveBright
Replied by DaveBright on topic Angel dust
Mike, you look much younger in that photo.....
Last edit: 11 Aug 2015 23:25 by DaveBright.
Time to create page: 0.374 seconds
