17 Dec 2015 15:33 #7399 by Chris001
Worryingly, we arrived at the same mistake independently!
TLAR I think stands for That Looks About Right.
17 Dec 2015 16:49 - 17 Dec 2015 16:52 #7400 by JonTappin
Chris001 wrote: Worryingly, we arrived at the same mistake independently!
Ahh....that makes sense then, the f3a model I design and built in the 90's was done with exactly that design philosophy :)
On the basis you both made the same mistake, there are probably loads of other Atlas' all over the world the same as yours!
Last edit: 17 Dec 2015 16:52 by JonTappin.
  • Phil-C
17 Dec 2015 18:15 - 17 Dec 2015 18:17 #7402 by Phil-C
So, we are talking 1/16", in real money. The thickness of a carpenter's pencil.
Last edit: 17 Dec 2015 18:17 by Phil-C.
17 Dec 2015 18:35 #7405 by Chris001
Blimey Phil you're way out, 1/16" is actually 1.5875mm no where near 1.5mm ;) and what use is a pencil? it's far too wide to be accurate, a knife line on the other hand... that's something we can work with, problem is it only shows up on balsa if going across the grain.
Have you finished the furniture building?
  • Phil-C
17 Dec 2015 18:42 #7406 by Phil-C
Many years ago, I helped to design and create a jig for Slazenger to drill a golf club head for the shaft to fit in. We asked if there were any drawings, and were told NO. We asked where they wanted the hole drilled, and the foreman, with his carpenter's pencil, drew a cross on the wooden blank and said "B'aht theeer, Lad!"
(Excuse Yorkshire twang but the factory was in Wakefield)
17 Dec 2015 18:43 #7407 by MikeSeale
Chris001 wrote: TLAR I think stands for That Looks About Right.
Correct
17 Dec 2015 18:46 #7408 by Chris001
Do you have a photo of this plane?
As to Mike and I making the same mistake and others doing the same, I think it's unlikely to happen for anyone putting it together for a glow engine because I'm assuming the bits marked "Bearer" are what you mount the engine to, and they are running parallel to the down thrust angle.
17 Dec 2015 18:46 - 17 Dec 2015 18:48 #7409 by Phil Ford
Chris don't don't get too technical with dimensions! mm, inches, thou, etc. Phil C uses the old measurement of inches and that looks about right. It has worked out alright for him for millenia. :lol:
Seriously though, I did also in repairing a damaged model's firewall I added in a degree or so of thrust angle. After the first flight figured out that the angle had already been built in to the fuselage, so instead of 1.5 deg I had inadvertently given it 3 deg or more. Epoxy said not a chance of cutting out again. :( Good old flat washers under motor mount corrected it. Mustang flies great now. Although in fairness the Mustang is not a precision flight model.
Last edit: 17 Dec 2015 18:48 by Phil Ford.
17 Dec 2015 23:06 #7411 by DaveBright
I think I remember that flight Phil!
17 Dec 2015 23:23 #7412 by Phil Ford
DaveBright wrote: I think I remember that flight Phil!
Yes it was you... :lol: Very interesting launch and initial flight. Amazing how well a few well placed washers can do. It's quite flyable now... ;) Shame about the Lipo though!
