06 Dec 2015 10:36 #7278 by Chris001
It's very satisfying watching the hot wire gracefully cut through the foam, and thankfully I no longer need to keep sketching out a diagram to try and illustrate Mike's gravity feed machine to people, I can just point them to Mike's video.
I've just released the fuselage from the jig and to my surprise it didn't spring apart :)
06 Dec 2015 17:36 #7290 by Chris001
I've decided I'm a plodding builder rather than a speed daemon, I'd had hopes of be further forward than I am, but all in all it's not been a bad weekend, on Friday I had no wings and only bits of wood cut up, today I have foam wings, and the fuselage is taking shape. Mike popped over to give me a new foam tail, which was really kind of him, and I was able to pick his brains about the next steps. I didn't notice any sharp intakes of breath as he looked over what I'd done so far, maybe he was just being polite :unsure:
Any updates from the other Atlas builders?
07 Dec 2015 08:19 - 07 Dec 2015 08:20 #7304 by Phil Ford
Chris001 wrote: It's very satisfying watching the hot wire gracefully cut through the foam
Not wanting to hijack the thread but.......A bit "Heath Robinson" but by God it works! :woohoo: Minimal effort too. Could start cutting out Delta wings?
Chris001 - If you do not understand "Heath R" ask some of your peers. :lol: He was a master of it.........
Last edit: 07 Dec 2015 08:20 by Phil Ford.
07 Dec 2015 17:18 - 07 Dec 2015 17:19 #7306 by Chris001
Phil, I feel that liking Mike's... 'contraption' to an invention by Heath Robinson is quite disrespectful.
However I'll admit there is one area of the design that would trouble me if it were mine... Mike used a number of combs for the fine adjustment of the fishing line, however they were not all identical. This is troubling for many reasons, first is the possibility that he purposely bought mismatched combs, to my mind that requires a certain amount of planning and effort as it quite likely involves going to more than one shop. The second possibility is that he raided whatever he had in the house... this is perhaps even more disturbing for how many combs does one man need in stock at any one time? And does this mean he is currently combless. Troubling thoughts I know, and it's been keeping me awake at night.
Last edit: 07 Dec 2015 17:19 by Chris001.
07 Dec 2015 18:15 #7307 by MikeSeale
Heath Robinson is fine...although I'm not sure that his machines did anything useful!
As for the combs...whilst at Castlepoint, I popped in to Asda and bought two combs for £1. They were the same but different colours. Back home, I realised I needed another comb, and Morrisons sell a pack of three mismatched combs for £1. The combs are the magic ingredient and carefully hidden away from view so that no one can reverse-engineer the machine
07 Dec 2015 18:37 #7308 by Chris001
Mike, I just realised why you cut the balsa at F5, I'm thinking hard as I don't want to admit defeat and cut it there too ;)
It's not that I don't know what needs to be done, it's just working out the best way to achieve it... nicely.
09 Dec 2015 23:04 #7330 by Chris001
It's beginning to look 'cavernous' in there Mike ;)
10 Dec 2015 10:06 #7331 by John Bannister
Looks good Chris to good too fly, at least for me. I got bored with fuselage so started on the wings and tail and am trying to pluck up courage to put the skins on.
If you think Mike's machines look Heath Robinson take a look at these.My Machines
John`
10 Dec 2015 19:37 - 10 Dec 2015 19:38 #7335 by Chris001
My problem is that every time I see it John, I can't help thinking "boat", not "plane", it might have something to do with the lack of wings!
I do hope it does flies okay, but I will not find that out for quite a while. Your wings are looking good, how far did you get with the fuselage? I'm thinking I might skin the tail over the weekend, I can't do much more on the fuselage as I'm waiting on a Hobby King order that I'm beginning to think has gone astray. :unsure: it's got four 10mm motor mount spacers, and without them I can't position the motor and work out how to do the front end.
As for Heath Robinson looking contraptions, as long as they do the job ;)
Last edit: 10 Dec 2015 19:38 by Chris001.
10 Dec 2015 20:36 #7337 by Chris001
I think it's time for a new radio to match the era of this plane:
www.rcgroups.com/forums/showthread.php?t=2558589
Time to create page: 0.675 seconds
