9 years 5 months ago #8437 by
I'm way behind on my blog, mostly because I just want to get this thing done and in the air, it hurts not having a plane to fly :(
But I thought I'd put up a few pics here.
I've still got the leading edge of the wing to do, and I'm putting it off because I'm not sure how best to approach doing it, so any tips or advice would be most welcome.
9 years 5 months ago #8441 by John Bannister
Looking good Chris How did how do you cut the balsa round the retracts
Regards John
9 years 5 months ago - 9 years 5 months ago #8443 by AlanF
For the leading edge Chris I think I would stick a length of balsa , slightly over size to the LE. Then transfer the full root and tip section to each end of the wing either by attaching templates or by drawing. Find the max chord of the root and tip, transfer to the balsa and then draw a connecting line along the full span. This should give you a sanding guide and account for any washout and/or preserve a semi symmetrical wing section ( I assume yours is symmetrical)
Stick masking tape to protect the veneer and plane and sand until all bits of the balsa that aren't leading edge shaped are removed B) Remove the masking tape for final finishing.
If you have intermediate wing sections you could create some gauges to check the LE shape at various stations along the wing. Otherwise its down to checking with a straight edge and MKI eyeball.
It'll be interesting to read other peoples method of adding a leading edge.
Last edit: 9 years 5 months ago by AlanF.
9 years 5 months ago #8444 by Chris73
Or you could just attack it with a sanding block until it looks about right ;)
9 years 5 months ago #8446 by
Hi John, the balsa around the retract was cut with a scalpel and then sanded, but the cut out was already established in the foam, so it was just a case of sanding back to the foam. I think it would be a bit more tricky if the balsa was unsupported like in a built up wing.
Thanks Alan, the leading edge is already glued on, so I'll mark out the profile at either end, and center line and just go for it, I guess.
Chris, You surprised me, I thought you'd suggest a belt sander, I didn't know you did subtle and refined :P
9 years 5 months ago #8449 by MikeSeale
Attack it with your razor plane.
Use the plane to cut the leading edge into a trapezium shape. Then round the trapezium to a rough leading edge. Then 120 grit sanding block. Should take about 10 minutes for each wing.
Time to create page: 0.313 seconds
