WMAC Group build - Impressivo
11 years 8 months ago #946 by MikeSeale
Electric motors do not vibrate so 2mm ply will be fine. I have some 2mm screws which I can bring along to the next meeting. Thread lock not required...again, no vibration. Velcro straps are fine for battery restraint. Foam be is fine too, the battery will not get very warm. Not sure why you would want to make the model heavier by beefing up the floor? Heavier means faster landings which means MORE chance of damage.
Tips? Just one. Assume the designer knew what he was doing and build it as designed
11 years 8 months ago #947 by kevinross
Phil-C wrote: My motor has arrived as well. Think I'll do your mod, Kevin. Are the two extra holes repeated in the bottom, ie one for each motor vent?
Phil - Yes i have now added two holes on the lower surface - I have also replaced those sections with 2mm ply - Look closely at my pics - kevin
While I'm asking questions, how should we restrain the battery? Would velcro straps be best for holding the batt? I take it a foam bed is not preferred for these hand-warmer power packs.
I am thinking of beefing up the internal floor a bit before cladding the fus. Before anybody says 'owt, my landings were perfect today.
Phil see attached photo showing a very light reinforcement to false floor - That should be enough to support a velcro strip and prevent the floor being ripped out when removing the battery
Phil
11 years 8 months ago #948 by kevinross
Stuartmck wrote: Just been checking Fuz bits, 1/4 sq extremely hard, does not wish to bend to shape. Tried soaking, but not good. Might have to raid scrap box for something more suitable.
Stuart
Hi Stuart - Yes i found the same with some of my 4mm (3/16) longeron stock -I actually cut and spliced some of it to place the hard section at the rear and the softer sections for the front curvy bits
11 years 8 months ago #949 by
The extra strip of 4mm sq was what I had in mind, Kevin. Also use of 2mm ply top and btm at the rear.
11 years 8 months ago #950 by kevinross
RE - top or bottom elevon hinge - I have gone with lower servo / elevon horns as per manufacturers preference but feel safe because i am installing metal gear servos. - The attached picture shows the clearance.
11 years 8 months ago #954 by
Yes, I did mean the 3/16. When you get to my age, you remember things as being bigger than they are/were! Finally managed by soaking and weighting to get them near to shape.
I agree with Mike re motor mtg, with the size of the former, apart from lack of vibration,most of the strain will be taken thro' the fuz sides - build as per plan.
All on hold now, am away for a few days.
Happy New Yeat to all.
Stuart
Time to create page: 0.335 seconds
