WMAC Group build - Impressivo
11 years 8 months ago #1059 by Phil Ford
Phil-C wrote: Some may have spotted that this missile is a bit outside my comfort zone.
Phil
You can always throttle back a bit! :P
11 years 8 months ago #1063 by DavidTappin
Hello from sunny Schiphol airport (complete with with free WiFi)
Phil said
I could always take the prop off and go slope soaring
You could also try putting the prop on back to front, that would slow you down a bit.
David
11 years 8 months ago #1064 by kevinross
David[/quote]
Based on my finished model gross weight coming out at about 826gm (226 above the kit design) and from what i've seen on various Youtube videos, this is designed for speed and appears a bit of a hand-full post launch until some flying speed has built up so i will be doing initial flights with larger diam fine pitch props to give better acceleration and limiting top speed. (but i'm told most R/C equipment has a special channel called Throttle or something which has a similar effect)
11 years 8 months ago - 11 years 8 months ago #1074 by kevinross
I am planning on having some peel off type decals made up for our group build. They will cost about £2-00 for the pair if we select the larger sizes. I would plan to order 6 off in black & 6 off in white to enable some contrast against various colour schemes. If you are interested, please advise which font you prefer for the left decal and the right decal and if you would like dark or light colour. I will go with the majority input.
Last edit: 11 years 8 months ago by kevinross.
11 years 8 months ago #1076 by DavidTappin
Nice idea, thanks Kevin.
My choice would be middle picture starboard wing size in black.
Regards, David
11 years 8 months ago #1077 by MikeSeale
I'll go with the majority but must admit that I preferred the one you showed on Friday, which had lower case lettering.
Time to create page: 0.348 seconds
