WMAC Group build - Impressivo
11 years 5 months ago #1235 by kevinross
DaveBright wrote: balls, dark colour it is!
Never mind the colour Dave - Just concentrate and make sure you don't glue it with coffee then drink the Cyno !!
11 years 5 months ago - 11 years 5 months ago #1243 by
Any tips on how to fix the tiny ferules on the 0.8 mm wire linkages?? If I cyano them, will they come off if I try hard enough? :S
And it's not the workshop, David. I was allowed indoors 'cause it were cold.
Last edit: 11 years 5 months ago by .
11 years 5 months ago #1244 by DavidTappin
Phil C asked
Soldering will do nicely Phil. Don't worry about the G/F horns, just like committee members they can take the heat. So make sure that the z bend is at the servo arm end!
David
11 years 5 months ago #1246 by MikeSeale
I'm not at that stage yet, but you could also try a crimp prior to soldering for 'belt and braces' approach. However, I'll probably put a z-bend both ends. Get it all lined up before gluing the horn onto the control surface.
11 years 5 months ago #1247 by kevinross
I simply made the first 90 deg bend with pliers then the second of each Z bend by hand. after installation of horn and servo. (Z bend pliers make too large / wide bend causing excess slop)
11 years 5 months ago #1251 by
I did my Z bends with fine nosed pliers, then, made keepers out of a bit of plastic.
Soldering the other end seems to have worked, though they looked like Aly to me.
Time to create page: 0.578 seconds
