Curare EP Resurrection
9 years 7 months ago #8261 by
Replied by on topic Curare EP Resurrection
Great to see you making progress on this Phil, I too have been busy and to the untrained eye it looks like blocks of balsa gluing up, but to those in the know, they might be wing tips and the beginnings of a tail fin.
With the glue if you feel confident in a good tight wood against wood joint then the PVA is probably fine, if there is daylight, epoxy has gap filling properties that might be more advantageous.
9 years 7 months ago - 9 years 7 months ago #8262 by Phil Ford
Replied by Phil Ford on topic Curare EP Resurrection
Thanks Chris, The former is a good fit so PVA then.
I have started on the fuselage as it is a bit fiddly and time and time consuming, leaving the wing to just tidy up and do some infills when I get some sheet balsa (missed it off the order.. :( )
Hoping to get up to Cashmoor tomorrow so maybe Monday have a go at F4, this one is critical because it sets the height of the snakes relative to the servos and helps support the servo tray and wing mounting plate and the spread of the fuselage. All good fun. :lol:
Last edit: 9 years 7 months ago by Phil Ford.
9 years 6 months ago - 9 years 6 months ago #8310 by Phil Ford
A week has passed already. :ohmy: Have made good progress I think with the Curare between home maintenance jobs. Forward wing former fitted but I was slightly out on the holes. I had not allowed for the fact that as the wing slides forward on the saddles it will rise about 6mm. :( Had to do a hack from inside the retract bay - but it fits perfectly now, just not pretty to look at but functional. ;)
Servo tray is installed and servo ready for connecting up again.
Further down the fuselage I have dropped in new stringers and bridged the joints with some more balsa. Not pretty either. I have doubled up the top stringer for increased strength and have added two more stringers too. Fuse is nice and rigid now..... :) Ready nearly for skinning.
Which begs the question from a novice balsa basher. How to form the curve in sheet balsa? Glue one edge then wet the balsa and tape it down to shape? How wet does it have to be?
Last edit: 9 years 6 months ago by Phil Ford.
9 years 6 months ago - 9 years 6 months ago #8313 by flyingpete
Replied by flyingpete on topic Curare EP Resurrection
Phil
Fill the washing up bowl with water and imerse your bit of balsa.Take it out and pat dry with kitchen roll to remove any water and you can slowly bend it to shape and tape it into place whilst the balsa dries out and then glue.
This is best done in a nice warm place otherwise it will be ages to dry in a cold workshop.
You can also use the foaming gorilla glue as this reacts and sets with moisture.
Last edit: 9 years 6 months ago by flyingpete.
9 years 6 months ago #8337 by Phil Ford
Thanks Pete.
I have had go today at bending and hopefully finish the skin on the fuselage. First attempt resulted in the balsa splitting. Maybe not soaked enough? Anyway, had another go and have now got a curved piece fro the top side of the fuselage. :)
I'll be glad to get to the point of re-sticking down the covering although it ain't gonna be a pretty. I have got loads of blue Profilm and Solartrim but not in this blue :( Minor issue, the main thing is to get it flying again.
Hopefully Wednesday I can sort out the wing and then............whatever! ;)
9 years 6 months ago #8363 by Phil Ford
Curare all ready to go. Covering is not pretty but will sort it out later after I see if it flies. ;) I'll put some pics up later.
Off subject a little - Fitted the Cherokee with a new OS46, and replaced items that I nicked for other models, radio, wheels, etc. Ready to fly again soon. :)
Must stop "borrowing" bits on a grand scale. Gets expensive to put it all back again... ;)
