BVM Mig.15
8 years 10 months ago #11160 by flyingpete
Last job before I reluctantly shut the workshop door's for Christmas are the underwing tank's/pylons.
Very strange from BVM is that the pylons are made up from ply and balsa and not f/glass.
Anyway first job is to drill 6mm holes top and bottom for the alloy guide tubes. Make up the pylons from 3/8 balsa and 1/64 ply and scribe into the wing tank and underside of wing. Once happy glue to the protruding alloy tubes.
Next job is make up the fins with ply core and balsa top and bottom. Cut mounting slots with a dremel and glue fins to tank sides
The fixing in the wing is a 6 mm threaded tube which will be epoxied in place and 4/40 bolts screwed up through the alloy tubes to secure.
Filling and painting will be next job
8 years 10 months ago #11161 by flyingpete
Few more
8 years 9 months ago #11163 by Phil Ford
Going on in leaps n bounds. Well earned break too.
8 years 9 months ago #11165 by DaveBright
Replied by DaveBright on topic BVM Mig.15
Lovely stuff
8 years 9 months ago #11166 by 4Pedalsfly
Replied by 4Pedalsfly on topic BVM Mig.15
Great work Pete - Look forward to seeing your next postings.
Enjoy the festive season.
8 years 9 months ago - 8 years 9 months ago #11173 by flyingpete
Sneaked a couple of jobs in today.. Cut the slots for the nose gear hinges, removed the single hinge pins and made up a full length pin. Roughed up the inside with some 80 grit and glued with med cyano
Last edit: 8 years 9 months ago by flyingpete.
Time to create page: 0.320 seconds
