9 years 10 months ago #7341 by MikeSeale
Some sand corners whilst others cut corners.
9 years 9 months ago - 9 years 9 months ago #7390 by
Trying to be too clever, when I drew out the motor mount I worked out the thrust angles and shifted the holes to compensate.
However I've just discovered my mistake this evening, on the plans from former 3 down to the nose the whole fuselage section has been angled to that of the down thrust angle.... This means no compensation for the down thrust was needed and I've basically mounted my motor 1.5mm above '0' line.
Needless to say I remained calm, I didn't say anything too outrageous, instead I went to the fridge and pulled out a bottle of Wolf Rock Red IPA (one I've not tried before).
Can anyone hazard a guess as to how badly this mistake affect my Atlas in flight? I guess there are bound to be mistakes in a first build, but I'm kicking myself for not seeing it in time.
Last edit: 9 years 9 months ago by .
9 years 9 months ago #7391 by Chris73
Can you not just glue in some dowels to plug the original holes and then re-drill in the correct position?
9 years 9 months ago - 9 years 9 months ago #7392 by kevinross
Replied by kevinross on topic Winter build project: Wolfgang Matt’s ATLAS
I agree with Chris 73 - You could also glue some thin ply washers across the repair to create a clean area to re drill.
If your rework is criticised - say its a reinforcing modification !
Last edit: 9 years 9 months ago by kevinross.
9 years 9 months ago #7393 by JonTappin
Hi Chris, If you are worried about it do as Chris H suggests, it's an easy job. However, I would be very surprised if being 1.5mm of the original vertical position would make any difference to flight characteristics, as long as the downthrust is correct. When you install the nosering and balsa cowl, just line it up with the revised position.
9 years 9 months ago #7395 by MikeSeale
If Chris does fill the holes and move the motor down, his will be 1.5mm lower than mine because I made the same mistake. Mine is not going to change since I've already built up the nose and I'm convinced that:
  1. It will make no difference
  2. I will probably build in other small errors that might cancel out this error
  3. Who says Wolfgang Matt got it right all those years ago? Did he experiment with the thrust line until it was perfect or did he make a TLAR model and when it flew well he left it alone?
  4. The vertical weight distribution of the electric setup is going to be different from the 40-year-old IC setup and who knows whether this will affect the desired thrust line. I have read that Prettner recommends a different dihedral angle (more) for the electric Curare due to the vertical CG being higher than the IC version with a pipe below the wing
Time to create page: 0.522 seconds
