Christmas Curare EP
24 Nov 2015 21:34 #7135 by MikeSeale
ronp849 wrote: This will cause the wirewrapping to become loose when the solder melts.
Can you explain this sentence?
Phil is looking to add a solder adapter to a steel rod. No wirewrapping involved and he must use enough solder to fill any difference between the wire diameter and the cup diameter.
  • ronp849
24 Nov 2015 22:16 #7136 by ronp849
Replied by ronp849 on topic Christmas Curare EP
Hi Mike
I was thinking in more general terms as per Jons photo where he has joined two wires with wire wrapping. I agree my comment does not apply when joining a wire to a clevis.
24 Nov 2015 23:29 #7137 by MikeSeale
Ah, sorry, I had not looked at the photo. So Phil will have to use solder adapters and join some rods with a wire wrap too. Fun times ahead.
25 Nov 2015 17:20 - 25 Nov 2015 17:30 #7141 by Phil Ford
Elevator rods done ;) (see stories of stupidity)
Come across another glitch. Motor install. In the qefimagazine review the motor used was the Lipolice 510Kv. I have used the Turnigy SK3 5045 660Kv. Physically they are the same size give or take a millimetre lengthwise. When the SK3 is mounted as per the review and instructions and the cowl is pushed on as far as it will go the prop driver is still 10 or 11 mm short. :(
Plus with the cowl pushed far back it now overlaps the front of the removable canopy by about 15mm. So it can't go there for starters either. :(
Looks like about 25mm short in total.
See images.
Somethings going on......... :angry: A the least i have got to add spacers of 10mm to get the driver out of the cowl and then there is the issue of the cowl - cut it down? Should'nt have to..
Scratching head - assembly stalled.
Last edit: 25 Nov 2015 17:30 by Phil Ford.
25 Nov 2015 17:40 #7142 by MikeSeale
I'm not sure why you thought the two motors were the same length. I'm building my Atlas to accomodate the Lipolice motor one day, but in the meantime the SK3 is mounted on standoffs - photo below.
Hobby king standoff and spacers
The NTM 35 spacers have a 3mm hole and the NTM 42 spacers have a 4mm hole
25 Nov 2015 18:06 - 25 Nov 2015 18:51 #7143 by Phil Ford
I have just checked the cowl. It is 120 mm from front to rear. The wooden stand-off is 40mm then add the motor length (prop driver to X plate) which is 58mm. total is 98 mm, therefore need 20mm more spacing. Or another motor. :(
I am going to check on some more SK3s. I think the lower KV ones are longer in body.
Edit: Just been checking dimensions of various motors and equivalents. The recommended Lipolice 510kv 12T is near same as my SK3 exception being the stated KV. Also found this interesting page on motors. Most motors are made by SunRay Technology or ChinaHiMark Co.
So it looks like my only option is stand-offs or dump the EP idea! Not spending any more cash on motors. OS55 might get in with a chance.... ;)
Last edit: 25 Nov 2015 18:51 by Phil Ford.
25 Nov 2015 18:52 #7144 by Chris001
Replied by Chris001 on topic Christmas Curare EP
PhilF51 wrote: I have just checked the cowl. It is 120 mm from front to rear. The wooden stand-off is 40mm then add the motor length (prop driver to X plate) which is 58mm. total is 98 mm, therefore need 20mm more spacing. Or another motor. :(
That would concur with Mike's measurements and just needs 2 lots of the 10mm spacers, probably all of £3 including postage from Europe. Just remember you need two lots, otherwise you'll need to put in two orders... don't ask me how I know this. :pinch:
PhilF51 wrote: I am going to check on some more SK3s. I think the lower KV ones are longer in body.
I think the form factor on the 5045s are the same except for the helicopter ones, but I've only really looked at the 660KV and 500Kv.
It's the clamp on prop adapter on the Lipolice motor that helps make it that much longer.
25 Nov 2015 19:16 #7147 by Phil Ford
The compression adaptor makes it slightly longer but probably not what's needed. I sense a stitch up here... :unsure:
20mm set of 4, Hobbyking . no stock, Doh!
Any other sources. Such simple things to make with lathe and some ally round bar. :(
25 Nov 2015 19:28 #7148 by Chris001
Hi Phil,
They would probably rattle around anyway the I/D of the ones you linked to is 5.1mm, the ones Mike is using are either 3mm or 4mm I/D, the motor X mount takes M4 bolts.
25 Nov 2015 19:32 #7149 by Phil Ford
Chris001 wrote: Hi Phil,
They would probably rattle around anyway the I/D of the ones you linked to is 5.1mm.
They won't rattle unless they are loose.. ;) I am using 4mm bolts. I have found some steel spacers but are far to heavy for model work.
Of course I won't need all this agro if the OS55 gets lumped in.
Time to create page: 0.379 seconds
