Christmas Curare EP
16 Dec 2015 17:55 #7387 by MikeSeale
I've been flying with a 11x8.5 for many flights but did try a 12x10 the other day for one flight. Current was 80A and the vertical was better than it was with the 11x8.5. Speed in level flight seemed about the same. When I got home I looked at available APC props and will be getting a 11x10E soon and might also try a 11x9 (not electric). Good to know that the 11x10 was still in the 60's for current because I don't really want to be running at 80A because (even with throttle management) the flights are going to be a lot shorter than at 60A.
As for me itching to fly it...the truth is I was itching to see it fly. I offered to fly it at about 10.30 and it didn't fly until well after lunch. I'm also keen to see YOU flying it...there is no point in buying all these models if you revert back to flying the orange foamies and a Wots Wot all the time!
16 Dec 2015 18:47 #7388 by JonTappin
MikeSeale wrote: I'm also keen to see YOU flying it...there is no point in buying all these models if you revert back to flying the orange foamies and a Wots Wot all the time!
What he said :)
16 Dec 2015 19:30 - 16 Dec 2015 19:32 #7389 by Phil Ford
JonTappin wrote: What he said :)
Not defending the Wot 4 debacle ;) but the Wots Wot is fun, but does take some care when landing which I am just getting used to. Orange foamies have not been around for over two months now and I have some interested purchasers. :lol:
Now that I will have more time during the week (when it ain't raining) I'll be able get more flight experience which has been limited.
Last edit: 16 Dec 2015 19:32 by Phil Ford.
07 Jan 2016 13:16 #7618 by Phil Ford
So far had loads of flights and loving it. :) With only one battery too! :(
Ordered two 4000maH 60C Zippys. These are virtually the same length and height but a lot wider. Weight of these Zippys is 693gms compared to 645gms for the Turnigy. The extra width required repositioning of the regulator more forward (more juggling of wiring) but simple enough as the output wire was quite long. The new packs may have go back a little to maintain CG.
Jon, you had 16 clicks of right rudder dialled in on the TX. So, while indoors I removed the cowl and checked the firewall position and motor adaptor. There is no right thrust built in. Do you think a degree or so of right thrust would do the trick to centre rudder. Never heard you mention anything before regarding your IC Curare.
07 Jan 2016 14:28 #7619 by Chris001
Replied by Chris001 on topic Christmas Curare EP
If you look at the plan Phil it suggests:
Down thrust 0-3º
Right thrust 2º
Plan: www.outerzone.co.uk/plan_files_05/5527/Curare_60.pdf
Why did you go for a 60C battery, the current handling of the motor is 60 Amps so even a 20C 4000mAh should provide 80 Amps. The 60C is heavier by about 100 grams, even more if you went for a zippy compact 25C, which is 557g if the specs are correct.
Really glad you're enjoying the curare, lovely looking plane and must be fun to fly.
07 Jan 2016 14:47 - 07 Jan 2016 16:13 #7620 by Phil Ford
60C? I wanted a pair of 40C Zippys but only one in stock. They are only 45 gms heavier, i weight them. The Turnigy 40C I have been using has not had a lot of use, yet starting to puff out and I have not asked for max amps often. In fact the Curare has been lifting off with no head wind at just under half throttle... :) :blink:
I had not looked at the "plans" (mine is ARF) but you obviously have so I'll shim the motor adaptor for right and see if that cures the rudder trim.
As a footnote: if the new packs are too heavy, I have another plane that will love 'em, but that depends on HK stock levels of the packs I really wanted. (I did not want to go down the Europe order route after the last fiasco.
Your Atlas must be nearly finished by now...... :lol:
Last edit: 07 Jan 2016 16:13 by Phil Ford.
07 Jan 2016 15:35 #7621 by Chris001
Yep, I've got quite a few plans on my computer now ;)
The Atlas is stalled at the moment awaiting news that my servos have been obtained from the suppler, and are ready to be sent on to me.
I'll be interested to know how the different batteries perform, as I have a vested interest ;) Preferable I'd like to have something that would be good for both the Atlas and the Mythos 50E, so I've got my eye on the 5000mAh 6s Zippy compacts, although I've heard both positive and negative reports on them from two club members.
07 Jan 2016 17:15 #7624 by MikeSeale
Here's a file I created a few weeks ago to compare different 6s batteries. Prices and stock availability will have changed since then, but you can see where the bargains are to be had
07 Jan 2016 23:03 #7630 by JonTappin
You will definitely need right side thrust if you have none, I thought it was already built into the front bulkhead though?
Can't really remember what I did with your rudder trim, but if it needs right trim then increase the side thrust. 2 deg would be a good starting point.
Time to create page: 0.335 seconds
