Sebart Mythos Throws
9 years 2 months ago #9270 by
Replied by on topic Sebart Mythos Throws
Thanks Jon, that looks like it will do.
9 years 2 months ago #9271 by 4Pedalsfly
Replied by 4Pedalsfly on topic Sebart Mythos Throws
Hi Guys - Am I missing something here, why not drill the rudder arm out at 40mm to match the servo arm ?
Is it perhaps to do with precise rudder movement ?
9 years 2 months ago #9272 by
Alas Colin, I've epoxied in the horns into the rudder which is glued onto the fuselage so any drilling would be fraught with danger now.
9 years 2 months ago - 9 years 2 months ago #9273 by JRI
Replied by JRI on topic Sebart Mythos Throws
I have dead-center tool that would safely do the drilling job Chris .. also a set of pin-vices for small drills.
Last edit: 9 years 2 months ago by JRI.
9 years 2 months ago #9281 by
Thanks John,
I didn't see your post until after I'd dived off in a different direction. Being a total cheapskate, I decided to go the DIY route
9 years 2 months ago #9314 by
With servos with metal output shafts, do you loctite the arm retaining screw, or is the grippy washer enough?
By the what Jon & Chris, the jig for enlarging the hole in the tail worked well, 4.5 hours to design it, build it and test it. :evil:
Okay, I used masking tape, a steel ruler and a scalpel, but the jig would have been more precise!
