This could be fun
12 Oct 2017 18:19 #14153 by Brian
The electric Gurke is quite expensive if you use the suggested Hacker motor etc. Modest offerings from HK bring the price to a reasonable figure. I'm a bit nervous of laser cut kits with no plans though. The more I look at the video, the more I want one, looks like pure fun, and very portable too. If I do build one, I'll have to use DeLuxe Materials aliphatic glue. Cyano gives me a runny nose, red eyes and a hacking cough, and not a shred of sympathy from missusladywoman.
12 Oct 2017 18:40 - 12 Oct 2017 18:40 #14155 by Chris001
Replied by Chris001 on topic This could be fun
Chris73 wrote: I did such an awful job of building the Minus Thermic that I put it in the bin, I dont think building is for me
Yep mine nearly ended up in the bin too! Don't be too hasty on giving up on the building malarkey, we've just got to find the right kit for you :evil:
Hi Brian, I'm using titebond II on the Begin' Acro as I have the same issue with CA, but I think for modelling the DeLuxe Materials aliphatic glue is nicer, but that might be just because the titebond is more yellow in colour!
Last edit: 12 Oct 2017 18:40 by Chris001.
13 Oct 2017 08:07 - 13 Oct 2017 08:08 #14158 by kevinross
[quote=
Chris 001 said - The only worrying thing for me is that I suspect there will be no jig building potential with the Gurke[/quote]
I'm sure you could prove yourself wrong Chris - without trying too hard !!!!
Last edit: 13 Oct 2017 08:08 by kevinross.
13 Oct 2017 13:52 #14161 by Chris001
Brian wrote: The electric Gurke is quite expensive if you use the suggested Hacker motor etc. Modest offerings from HK bring the price to a reasonable figure.
Hi Brian, I came across a PDF review of the Gurke (alas in German) and if you have a look on the second page you can see the motor mount. Being such a small plane there might not be a lot for room for manoeuvre with a different motors of slightly different proportions. Have you come across one on Hobby King's website that you think would do?
13 Oct 2017 15:10 #14163 by Dave Rogers
Replied by Dave Rogers on topic This could be fun
I’m up for the build too, looks great!
13 Oct 2017 15:19 #14164 by Brian
Hello Chris, I found an equivalent motor for the Gurke. Its from Purple Power, PPOM-2321-2050 £13. Speed controller PPESC 12AU £12.50. 2s7.4V LiPo from HKing
£4.10 . Servos HiTech HS65HB £16.43. Prop/spinner HKing HK#8482 £5.57.
I looked up a translation for "Gurke", it said "cucumber". That can't be right...............or can it?
13 Oct 2017 15:56 #14165 by 4Pedalsfly
Replied by 4Pedalsfly on topic This could be fun
Brian wrote: Hello Chris, I found an equivalent motor for the Gurke. Its from Purple Power, PPOM-2321-2050 £13. Speed controller PPESC 12AU £12.50. 2s7.4V LiPo from HKing
Brian - Thanks for the update on the "bits" - HS65 HB's seem a bit o.t.t Turning mg servos would be fine ( will confirm spec when back
from hols ). Tom uses Turnigy on his " Pussy Cat " which goes like stink with no known problems.
In an earlier thread someone said it had no control surfaces ?? presume from the video it's aileron & elevator, also what is the price ?
Thinking of having a go.
13 Oct 2017 16:19 #14167 by Brian
Hi Colin, the HB servos have graphene gears and are cheaper than the MG variant. I think a robust gear train will be needed as the force to twist the wing must be quite a bit more than that required to move a relatively small aileron.
13 Oct 2017 18:13 - 13 Oct 2017 18:16 #14171 by kevinross
Re the ESC selection - Digital servos operating wing twist may require higher than average BEC current capability from the ESC.
Last edit: 13 Oct 2017 18:16 by kevinross.
13 Oct 2017 18:37 #14172 by Brian
The designer suggested a 10A ESC, I thought the 12A would be OK. The HKing props are slightly smaller than the ones suggested too, puts less load on the motor, leaves a bit more juice for the servos...............hopefully.
Time to create page: 0.376 seconds
